For my waterfall, I have a catchment basin of 30 gallons. The filter discharges into the basin, then the overflow creates the waterfall.
That's how mine works also...except my basin is about 5 gals. |
My Project is currently in the layout phase.......still placing and angling ponds setting elevations.
Scored a cool LARGE fiberglass waterfall off craigslist for up on the deck, then cascading through several ponds to recirc. http://forums.pelicanparts.com/uploa...1726423367.jpg |
http://forums.pelicanparts.com/uploa...1726424332.jpg. My 550 at the Salem Pond. :cool:
^^^ It must have the Porsche diverter valve in it. :D
In our systems we reduce flow by: Bypass with valve - pump puts out 100% flow but some bypasses back through pump. Valve after pump - increases pressure drop of system decreasing overall flow. VFD - varies pump speed electrically Sometimes we use all 3 depending on application. In your application, valve after pump. Make sure you keep it cracked about halfway. |
Well, I have updated my pond situation. I added a ball valve to slightly restrict the flow. This did not have any effect on the pressure at the waterfall because the restriction is increasing the pressure to the inlet of my biological filter, but the output is just a gravity feed once the water level reaches a certain point. A couple of pics below:
From Pond Pump>to Anti-backflow valve> to Flow Control Ball Valve> to UV Filter> to Biological Filter> to Waterfall. Pond is on other side of the fence. The valve is only restricted 25-30% http://forums.pelicanparts.com/uploa...1726511369.jpg My Baby Pond: http://forums.pelicanparts.com/uploa...1726511561.jpg |
| All times are GMT -8. The time now is 06:48 PM. |
