Which oil should I use.... in a Z-Turn?
Nope .... didn't do a search
![]() In a Z-Turn that needs the "good stuff" lacking in modern oils ... sorta like a 911... What do you guys use? I'm gonna gather specs and bug Lubey ... but what say ye? Both motor and trannies (Kawi and HydroGear 3100)... Brand and weights ... thanks! Are my HG Made in China dinky tranny filters I have on hand OK .... I don't like 'em, but skeered to deviate. Last edited by KFC911; 10-08-2024 at 03:27 AM.. |
Brew Master
My Super Z with a Kohler Command calls for 10w30 (IIRC) I buy whatever is cheapest honestly. I figure for the hours I put on my machine and the service interval (change it every spring) why go crazy spending more on oil? I use 20w50 for the Hydros since that's what Hustler recommends.
Nick |
I use 10W30 Lawn Mower Oil from Walmart in my John Deere Commerical Z-Trak.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
All of 'em have the HG hydros... either 2800 or 3100. Not much difference between the two, but their low oil capacity and high temps make me think REALLY good syn makes sense for those .... and $$$ doesn't matter to me. I have a 5 qt. Castril 20W50 on hand and two dinky China filters ... (HG branded) ... never used 'em on my baby Scag.
Motor Earl ... I'm thinking 20W50 from Mobil/Amsoil (with added ZDDP, etc.) or the syn Kawi stuff the dealer sells... I'll get specs and info later and compare. Need something designed for Z-Turn (air) verses auto earls.... Earl isn't earl no mo' ![]() Thanks! |
For my intended use ...
I could be TOTALLY over thinking this .So what ?
Bobistheoilguy.forum
I keed you not ![]() Mebbe it's Kontak... They nose stuff about these thingies... at least to me they do ... https://bobistheoilguy.com/forums/threads/20w50-for-hydrogear-zt-3100s.331524/post-5516476 Last edited by KFC911; 10-08-2024 at 09:25 AM.. |
I used to run Lucas 15w-40 in my Dixie Chopper with Kohler engine. I switched this year to Rotella 15w-40 T6. I use the same oil in the Hydro tank.
Peppy 2011 BMW 335d 1988 Targa 3.4 ![]() 2001 Jetta TDI dead 1982 Chevette Diesel SOLD
My guess is that pretty much any modern oil in the appropriate viscosity will be more than adequate (although I do stick with name brands).
If you want to go Synthetic, then any name brand synthetic in the correct viscosity is likely to be overkill. So probably get the cheapest brand name synth in the right vis. I have no thoughts/recommendations on the tranny.
Counterclockwise?
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Evil Genius
I LOVE my zero turn with the MyRide 3 shock supported suspension ride deck for my 5 acres.
really really saves the body abuse. https://www.toro.com/en/myride
Life is a big ocean to swim in. Wag more, bark less.
(the shotguns)
IIRC Valvoline had the best Zinc added 20W50 back when i had my 2.4. Not easy to find but at the time it was the top choice of internet experts.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Brew Master
I try not to overthink oil. As long the oil meets the required specification, I buy whatever is the cheapest. Generally that means I go to Rural King and buy their store brand oil. I do tend to buy a better brand of oil filter as I think filtration is more important than oil brand.
Nick |
Evil Genius
geezus its oil, dead dinosaur juice with flavorings, and in a lawn mower...........send your oil out for micron metal wear testing yet.......in a lawn mower?
paralysis by analysis.
Brew Master
Nick |
Mobil 1 20W50 V- Twin seems to have it.
I was tempted by the Toros .... just not apporopriate for that property ... but they are Niiiice ![]() My buddy with a Hustler SuperZ discovered that the brand of earl doesn't matter nearly as much as having some.... or any .He's an idjut .... smart and dumb .... $4K worth of dumb ![]() Nick ... any personal experience with the Hustler Flex forks.... I still think they might work on this model ... but how MUCH do they help.... the Hustler dealer says they help more that seat suspensions, etc. I might try 'em ... ' cause I can ![]() Just because
Bob's forum that I linked was informative ... Thanks all! |
According to my "new" dealer ... regular auto oils (new formulas over the last decade or so) ... are just "no bueno"... either in the motor or trannys these days. Earl is cheap
Brew Master
I disagree that the flex forks help more than the seats with shocks or springs. My mower has flex forks and adjustable suspension seat (standard style not like pictured above). At full speed I can still bounce myself pretty good. My next mower, if the Hustler ever decides to go, will probably be a Ferris with full suspension. Everyone I talk to about them says they're the smoothest ride going for a mower.
Nick Last edited by cabmandone; 10-09-2024 at 04:19 AM.. |
Thanks Nick! I just got my newest Scag yesterday .... haven't used it yet.
Does Elephant Racing do flex-fork mods ?
Brew Master
Maybe we should start "Mods For Mowers" or something like that. I mean, if people pay out the nose to modify a golf cart, why not a mower?
Nick |
