Which oil should I use.... in a Z-Turn?
Nope .... didn't do a search
In a Z-Turn that needs the "good stuff" lacking in modern oils ... sorta like a 911...
What do you guys use? I'm gonna gather specs and bug Lubey ... but what say ye?
Both motor and trannies (Kawi and HydroGear 3100)... Brand and weights ... thanks!
Are my HG Made in China dinky tranny filters I have on hand OK .... I don't like 'em, but skeered to deviate.
Old 10-08-2024, 02:38 AM
Brew Master
cabmandone's Avatar
My Super Z with a Kohler Command calls for 10w30 (IIRC) I buy whatever is cheapest honestly. I figure for the hours I put on my machine and the service interval (change it every spring) why go crazy spending more on oil? I use 20w50 for the Hydros since that's what Hustler recommends.
Nick
Old 10-08-2024, 05:24 AM
Send a message via AIM to fintstone
I use 10W30 Lawn Mower Oil from Walmart in my John Deere Commerical Z-Trak.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 10-08-2024, 06:25 AM
All of 'em have the HG hydros... either 2800 or 3100. Not much difference between the two, but their low oil capacity and high temps make me think REALLY good syn makes sense for those .... and $$$ doesn't matter to me. I have a 5 qt. Castril 20W50 on hand and two dinky China filters ... (HG branded) ... never used 'em on my baby Scag.
Motor Earl ... I'm thinking 20W50 from Mobil/Amsoil (with added ZDDP, etc.) or the syn Kawi stuff the dealer sells...
I'll get specs and info later and compare.
Need something designed for Z-Turn (air) verses auto earls....
Earl isn't earl no mo'
Thanks!
Old 10-08-2024, 08:45 AM
For my intended use ...
I could be TOTALLY over thinking this .
So what ?
Old 10-08-2024, 08:47 AM
Bobistheoilguy.forum
I keed you not
Mebbe it's Kontak...
They nose stuff about these thingies... at least to me they do ...
https://bobistheoilguy.com/forums/threads/20w50-for-hydrogear-zt-3100s.331524/post-5516476
Old 10-08-2024, 09:11 AM
peppy's Avatar
I used to run Lucas 15w-40 in my Dixie Chopper with Kohler engine. I switched this year to Rotella 15w-40 T6. I use the same oil in the Hydro tank.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 10-08-2024, 11:07 AM
My guess is that pretty much any modern oil in the appropriate viscosity will be more than adequate (although I do stick with name brands).
If you want to go Synthetic, then any name brand synthetic in the correct viscosity is likely to be overkill. So probably get the cheapest brand name synth in the right vis.
I have no thoughts/recommendations on the tranny.
Old 10-08-2024, 11:30 AM
Counterclockwise?
This is the same reason I would buy the best oil.
Rod
1986 Carrera
2001 996TT
Old 10-08-2024, 11:31 AM
Evil Genius
Rusty Heap's Avatar
I LOVE my zero turn with the MyRide 3 shock supported suspension ride deck for my 5 acres.
really really saves the body abuse.
https://www.toro.com/en/myride
Life is a big ocean to swim in.
Wag more, bark less.
Old 10-08-2024, 12:04 PM
(the shotguns)
berettafan's Avatar
IIRC Valvoline had the best Zinc added 20W50 back when i had my 2.4. Not easy to find but at the time it was the top choice of internet experts.
Old 10-08-2024, 12:37 PM
Brew Master
cabmandone's Avatar
I try not to overthink oil. As long the oil meets the required specification, I buy whatever is the cheapest. Generally that means I go to Rural King and buy their store brand oil. I do tend to buy a better brand of oil filter as I think filtration is more important than oil brand.
Nick
Old 10-08-2024, 03:27 PM
Evil Genius
Rusty Heap's Avatar
geezus its oil, dead dinosaur juice with flavorings, and in a lawn mower...........send your oil out for micron metal wear testing yet.......in a lawn mower?
paralysis by analysis.
Old 10-08-2024, 04:29 PM
Brew Master
cabmandone's Avatar
Yer in big trouble mister! I'm telling the guys in the 911 Tech section oil thread what you said. Yer callin down the thunder!!
Nick
Old 10-08-2024, 05:36 PM
Mobil 1 20W50 V- Twin seems to have it.
I was tempted by the Toros .... just not apporopriate for that property ... but they are Niiiice
My buddy with a Hustler SuperZ discovered that the brand of earl doesn't matter nearly as much as having some.... or any .
He's an idjut .... smart and dumb .... $4K worth of dumb
Nick ... any personal experience with the Hustler Flex forks.... I still think they might work on this model ... but how MUCH do they help.... the Hustler dealer says they help more that seat suspensions, etc.
I might try 'em ... ' cause I can
Just because
Old 10-09-2024, 03:47 AM
The Hydro hydro guys seem to suggest that 20W50 is better for the trannys ...
Bob's forum that I linked was informative ...
Thanks all!
Old 10-09-2024, 03:57 AM
That's what I thought too ...
According to my "new" dealer ... regular auto oils (new formulas over the last decade or so) ... are just "no bueno"... either in the motor or trannys these days.
Earl is cheap
Old 10-09-2024, 04:13 AM
Brew Master
cabmandone's Avatar
Just because
I have the flex forks on my machine and my dad had them on his machine. I'm honestly not sure just how much they really improve the ride. What tire pressure are you running on your mower? I think my Hustler runs 10 in the front and 8 in the rear but I could have that reversed. I think air pressure would probably help as much as the flex forks. I can put a caliper on the outer tube that holds the forks and measure the length of the tube. Those two measurements might help determine if what you've got is similar.
I disagree that the flex forks help more than the seats with shocks or springs. My mower has flex forks and adjustable suspension seat (standard style not like pictured above). At full speed I can still bounce myself pretty good.
My next mower, if the Hustler ever decides to go, will probably be a Ferris with full suspension. Everyone I talk to about them says they're the smoothest ride going for a mower.
Nick
Old 10-09-2024, 04:14 AM
Thanks Nick! I just got my newest Scag yesterday .... haven't used it yet.
Does Elephant Racing do flex-fork mods ?
Old 10-09-2024, 04:19 AM
Brew Master
cabmandone's Avatar
Maybe we should start "Mods For Mowers" or something like that. I mean, if people pay out the nose to modify a golf cart, why not a mower?
Nick
Old 10-09-2024, 04:25 AM
