You do not have permissi
The hydrogen engine fueled by water. A tech revolution.
BOHICA the perpetual motion machine. But this time it might be real.
Inventors: 1). 1998 https://steemit.com/innovation/@apis-mellifica/they-poisoned-me-has-the-inventor-of-the-car-been-removed-from-the-water-by-large-oil-companies The American inventor Stanley Meyer designed a motor on water. He claimed that water could be converted into hydrogen and oxygen, with less energy than released during the combustion of these gases. 2). Same Peugeot 405, different Iranian names? https://www.tehrantimes.com/news/434002/First-Iranian-water-fuelled-engine-system-to-be-commercialized https://supercarblondie.com/scientist-alaeddin-qassemi-invents-water-powered-car/ 3). Toyota’s New Water Engine Will Destroy the EV Industry https://old.bit_____chute.com/video/f3UrAZsuAYeY/ (remove spaces) "The secret to water power is not to slowly separate it into hydrogen and oxygen between the two plates, but to get the dielectric (the water) of that capacitor to catastrophic breakdown abruptly. Like when a capacitor fails from too much voltage it blows a hole through the dielectric. It is just a matter of raising the voltage in steps. This is how Stanley Meyer was doing it." The tech: Remember taking 9v battery leads and sticking them in salt water? One bubbles H2 and the other O2. I suspect the new process using plain water uses high voltage which may be pulsed. Perhaps water vapor is applied. It's all proprietary right now. Storing Hydrogen in tanks is useless and dangerous: Low density. High pressures. Leaks. =Hindenburg. So this new tech creates hydrogen right near the intake point on demand in an ICE/Otto cycle. The 'fuel' is kept as water until then. Good for automobiles, busses, trains, planes, home furnaces, gererators, etc. https://www.powereng.com/library/6-things-to-remember-about-hydrogen-vs-natural-gas Hydrogen’s adiabatic flame temperature is approximately 500 °F hotter than natural gas. NOX still has to be controlled: https://www.thechemicalengineer.com/features/hydrogen-the-burning-question/ A diffusion flame is where the incoming gas is surrounded by the products of combustion where the gas and oxygen in the air have reacted. This sleeve or cloud of exhaust products slows the combustion because the gas has now got to diffuse out through the cloud, and the oxygen has to diffuse inward. Hence the name “diffusion flame”. This flame is usually slow enough such that the heat of combustion is radiated to the surroundings without reaching the critical NOx temperature of 1,350oC. General use TBD. Actual efficiency and materials required TBD. But if want a clean new world without air pollution, this is how it can be done.
Meanwhile other things are still happening. |
Kantry Member
Remember this statement:
There is no free lunch. Best Les
Best Les My train of thought has been replaced by a bumper car. |
Everything I've read of hydrogen suggests it takes more energy to produce it than it delivers.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
I can't believe this kind of stuff is still circulating around. Obviously it doesn't work.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Thee water engine would almost certainly require very very pure water, delivered in glass jars. All impurities would leave a residue.
And, I suspect a slight revision of the laws of thermodynamics.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
But if a hydrogen 'carburetor' is possible and similarly-efficient to petrol, it would make sense wouldn't it? Odd that the USPTO won't find their own number.. https://www-search.uspto.gov/WWW-search.html But Google will.. " Hydrogen carburetor for generating hydrogen to run an internal combustion engine and method thereof " https://patents.google.com/patent/US20110210008A1/en The new process of hydrogen-harvesting must be more viable than the old carb type. If it works..it will be a game changer.
I suspect much like "cold fusion" it is just a pipe dream.
I will believe it when I see it has passed several tests by outside testing scientists.
So you burn hydrogen and get what again?
You think you can go from water to hydrogen + oxygen to water and get enough energy to power [anything] out of that. I bet you get scammed left right and center being that gullible. How many hydrogen carburetor warranties did they sell you this week? |
Converting hydrogen at the point of combustion solves all the problems.
Just wait. Even a decade or so. If we don't do it someone else will. (twittling thumbs and whistling)
Makes me think about Smokey Yunick.
Mike PCA Golden Gate Region Porsche Racing Club #4 BMWCCA NASA |
Can't we just drop some sodium or potassium in the water tank to get what we need quickly?
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Am I missing green text here? Sure you can unburn water with electricity to re burn or use in a fuel cell, but it's an assault to thermodynamic good taste. In no way is a hydrogen powered car a water powered car, it is an EV with a terrible battery. Unless solar and wind make excess power nearly free this will never be a good ifea
Bland
Electrolysis, or hydrolysis (where hydrogen and oxygen are produced from water) is an endothermic reaction. This means you need to put electricity (or energy) in to make it happen. This is the latent heat of formation.
When the bonds are broken either during combustion or via an electrolytic reaction involving a fuel cell, you get a portion of that energy back. Les has it right, there is no free ride here. The theoretical highest efficiency you can theoretically get with a solid oxide fuel cell like the ones I started my career developing is Carnot Efficiency, about 64%. In reality, you might get 40%.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
I hear that this is like the 100mpg carburetor. Maybe? - I'm just thinking. ...just askin' the question. More seriously, using our lowliest of the elements is awesome until you actually go to find some. Currently it's not looking so awesome on a carbon or net-impact basis (but... hint, hint... nuclear/solar/etc...) Though, selfishly, hydrogen issues in metals makes many of us metallurgists feel funny (down there). It's really interesting!
'78SC, lots of other boring cars... |
I read it completely wrong. It doesn't use any new new hydrolysis splitting technique.. It looks like just standard direct-injection hydrogen into an ICE. Then it uses water injection every other time or as needed to be a quasi 6-cycle steam engine. Already been done. Smaller radiator probably or perhaps one day no radiator will be needed. That water injection stroke also cools the motor from inside the cylinder. Hot-Cold-Hot-Cold. There is still a H2 storage tank but it's more efficient than H2 alone. Here I was getting all hot n bothered but am now disappoint in ya'll Toyota. https://myelectricsparks.com/toyota-presents-the-first-water-engine-2500-oc-and-dual-injection-to-outperform-hydrogen/
Bland
Back in 2000, I designed the fuel cell stacks in the trunk of this BMW with a hydrogen powered V-12 under the hood.
https://www.autoweek.com/car-life/a40677678/bmw-750hl-hydrogen-v12-sedan/
Feelin' Solexy
+1
Can you believe it has been 19 years since this legendary thread? Does anyone want a free gererator?
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
dolor et pavor Copyright |
