LinkBack | Thread Tools | Rate Thread |
Fell into a 2004 Honda Pilot that is extremely well maintained what should I know?
Thoughts from any Honda Experts appreciated
Sent from my iPhone using Tapatalk Pro
http://9309700485earlyturbo.wordpress.com Last edited by 93097004xx; 12-27-2024 at 09:07 AM.. |
1 owner. Extremely well maintained
http://9309700485earlyturbo.wordpress.com Last edited by 93097004xx; 12-27-2024 at 09:27 AM.. |
Control Group
Keep it forever
She was the kindest person I ever met |
Sorry 04 EXL 120k miles
http://9309700485earlyturbo.wordpress.com Last edited by 93097004xx; 12-27-2024 at 09:33 AM.. |
Did that year have the bad paint issues?
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle |
No paint issues on this one
http://9309700485earlyturbo.wordpress.com |
Timing belt /tensioner, use only OE Honda, or AISIN parts. Change the transmission fluid every 3-4 oil changes, its cheap and easy, just a drain and fill . Only OE Honda Fluid .
Ive replaced a few halfshafts, starters, alternators, ac compressors and a few other basic things on higher milage ones , but for the most part, simple maintenance, without rust, easy 250k. There is a valve adjustment interval also . I've had to cure a few missfires at super high mileage by a simple valve adjust, when other shops measured compression and condemmend the motor as having a bad cylinder/burnt valve . Super pedestrian , and about as exciting to drive as a lawn cart, but solid, practical vehicles . Nice score .
No left turn un stoned |
Thanks I figured heck for what paid for it in cash that’s only a couple weeks worth of a car rental so had to buy it. Nice to have a few back up drivers ect.
http://9309700485earlyturbo.wordpress.com Last edited by 93097004xx; 12-27-2024 at 11:28 AM.. |
D idn't E arn I t
If it develops a miss adjust the valves. Keep the trans fluid changed, ignore the book and change it with castrol synthetic or OE Honda fluid annually- it's absurdly easy to do. Honda transaxles from that era are fragile. Keep an eye on the belt tensioner as well.
rj[
In the movies only bad guys sleep in king size beds. |
I have a 2011 Odyssey with 153k on it that I bought new and it has not had even one problem.
