DIY Repair Screw Hole In Tire Tread?
Has anyone DIY repaired a screw or nail hole in the tread of an auto tire?
I think its just a matter of removing the screw, roughing up the hole, applying glue, and inserting a plug - right? One of our cars has said screw in the LF tire, these are snow tires that only get used part of the year, and my tire shop won’t repair the puncture as the tire is ten years old. I’m surprised I got so many years from the tires, but I’d like to get some more. There is adequate tread after all.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Did you get the memo?
Honestly if the tires are 10 years old I would trash them. But that’s just me
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
"A little nonsense now and then is relished by the wisest men." Wonka |
10 years? Trash 'em as you got good use out of them.
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
Youtube has several videos showing the technique. It's pretty much as you describe it. The problem is finding a quality plug kit.
I used to do this on my old truck tires (when I had zero money). 10 year old tires (even if they are studded snow tires) is pushing it for tire life. |
I seem to have cornered the market on road screws! I have had a ton of flats in the last few years.
I fix exactly like you ask. But, with one change. I use a drill mounted reamer. It really helps. I think that screws have an affinity for old tires and did just buy a new set yesterday-after a screw embedded last week. Try the drill method. It makes a tough job easier. |
I've used this sort of thing. ![]() But, one of our board members came on and said that where he works (IIRC) uses "Permacure II" plugs and they've had no problems or failures. https://products.techtirerepairs.com/product-category/tire-repair-materials/tire-repair-kits/
Snow tires are supposed to be really, REALLY soft compound, right? And as tires age they get harder. So yeah, 10yo snow tires may not be the best snow tires any more.
I have done this with great success many times, never once failed to hold pressure. In fact, I've done it three times in as many months on Mrs. Lee's car and the two dealer loaners we've had in that time. One was even totally in the sidewall and worked just fine. Fortunately, all these happened close enough to home that I could get home and do the plug.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
In 30 years I’ve put at least 25 in my cars. I’ve seen these plugs last 30k miles. I’ve never had one fail. |
I’m going to do the plug thing.
I drove this car, screw and all, up to the mountain to ski 2X last week. On the bits that were snow/icy, the tires were ok. Not like new Blizzaks, but ok. In the spring we’ll put the summer tires on and I’ll go looking for some spare wheels and see if there’s any deals on new snow tires.
Band.
I've done the mushroom plug thing a number of times on my DD and I have all the confidence in it. Done it near the center of a moto tire and feel fine about that one too; but I'll watch it a little harder.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
(the shotguns)
Use that slime kit myself. Works great and it couldn’t be simpler. I’d almost call
that kit a necessity.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Fleabit peanut monkey
Also cut the worm holder off of the handle and put the stem in the drill and "jog" the drill and the worm walks right in. (no grunting)
1981 911SC Targa |
Brew Master
I'm glad I know the guy who owns the local tire shop! I've never tried a push plug on a radial tire.
Nick |
That's the kit I use, have had to use it a lot. Last summer had a hole so big (quarter inch lag screw) I had use two strips for the Cayenne.
Tru6 Restoration & Design |
I’m getting to where I struggle to push hard enough to get a regular plug into the tread. Found these easier.
Just like the push in kind…you smear the glue on the plug. A lot easier to install for my old self!
