Car battery questiom
I can’t open my trunk to charge battery so I bought a charger to charge through cigarette lighter. Now it gives me a choice between AGM, leaf acid or lithium. I know it not lithium and that the battery is sealed. Any most likely battery used?
I had no idea there was different types. Thanks. |
D idn't E arn I t
Lead acid.
AGM=Absorbent Glass Mat- IE Optima bat. rjp
AOC/Hogg 2028 |
Did you get the memo?
Factory battery should be lead acid. AGM would be an upgrade and no OEM uses lithium that I’ve ever seen. I have lithium in my RX8 because I installed it for the hell of it.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
R&D guy
Location: the border between the states of inebriation & confusion
Many hybrids & EV's use lithium. Lithium batteries are also a factory option for the track-focused Porsche models (GT3, GT2, etc.) and original equipment in the McLaren MP4-12C. An on-line search on your car's brand and model should tell you which battery your car came equipped with. Last edited by dw1; 01-24-2025 at 06:36 PM.. |
Thanks All, I’ll take a look.
Cars a 986. I found receipt from previuos owner. Just says new battery @ $226 a couple years ago. I’ll check owners manual too.
986 is 100% a lead acid, I’ve replaced a lot of those.
Thank you very much.
R&D guy
If your battery is discharged to the point it won't activate the trunk release you will be charging for a looooong time through the cigarette lighter receptacle . I don't think it's designed to charge a discharged battery . It is designed to " top off and maintain " the battery .
The wire gauge is small so not much amperage flow . I know you are in a jamb and I hope it works for you . Good luck
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc Last edited by onewhippedpuppy; 01-25-2025 at 10:07 AM.. |
Battery is not dead. I’m just topping off.
Thanks. I need to pull the wheel liner again and keep fishing around for cable. If I can’t find, not sure what I do. |
I bought a Interstate AGM battery for $260 bucks and had to use my OBD2 Autel reader to enter a part number, battery type (AGM or wet cell) serial number and amp hours. I used the old part number, I added one to the serial number, and the rest was easy. I replaced the exact same battery in my 85 911, and only had to reset the clock for the time it took me to do the swap. No computer needed.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I swear this car wants me to sell. I had charger working last night. I went to set up today and it blows the 15 amp fuse before I plug charger into wall. I also bought this do dad to check the voltage through the lighter. That works fine when I replace the fuse. I contacted company.
Non Compos Mentis
My first generation Miata (1993) came with an AGM battery.
Useless tidbit: The battery is in the back passenger side corner of the trunk. With a 160 pound driver, the weight is equal on all four tires. |
I had AGM batteries in my 4 runner since the factory battery died. Normally, I use a typical trickle charger to top off over night if it hasn't been driven for 3-4 weeks. Works just fine. Anti-Gravity's Lithium in my 911s. I just love those batteries. it cuts itself off and there are three cranks left after a key-fob type device is depressed.
Battery Tender is what I use to top off the AGM. Maybe I am doing it wrong? |
R&D guy
I've heard "....you could pay a lot of a Mercedes (or other OEM brand) battery or save some money with this much cheaper one...", leaving out the option of an OEM equivalent aftermarket AGM battery which is the option I chose when I did it myself. Last edited by dw1; 01-27-2025 at 05:29 PM.. |
AGM have been used as OEM for quite a while, my 2004 BMW 530i was equipped with one.
DWBOX2000, your charger blew the 15A fuse for the lighter socket? Possibly capacitors in the charger pulling the amps.
87 930, Last edited by 908/930; 01-25-2025 at 04:20 PM.. |
