GM LS guys - catch can questions
I have a Gen 3 LS 5.3 in my S10 . I did not do the conversion . Had it a year now and it runs great . I have been reading about the potential benefits of adding a catch can .
Some guys are saying the OEM PCV system is weak and allows too much oil to make it to the combustion chamber . And some say it causes buildup on the valves . My engine is a early 2000's model with cable throttle body . So any of you running a catch can ? How did you plumb it ? How often do you check it or empty it ? Any negatives to running a catch can ? This is just a street driver , zero track time . |
D idn't E arn I t
I got one on my LS7 The PO installed. Done 13K miles (car has 26K)- I have never found any meaningful amount of oil in mine. More of a pain to get it out to empty than it's worth.
Given that, on a stock well-running engine I wouldn't waste my time. Such a small amount I highly doubt it affects octane. Probably more of a need for higher miles car that burns oil or cars with really sketchy tunes highly susceptible to detonation or under extreme use (boost) rjp
AOC/Hogg 2028 |
Banned
my general rule with catch cans, is that they catch was the engine already planned to consume, and thus make you feel like you've done something, but they actually dont do anything.
like all that **** is supposed to get pumped back into the intake and burned off, so like taking it out by hand, doesnt really improve anything lol. there was already a system made to do that for you. |
So in your guys opinions the stock PCV system is sufficient for a stock engine ? The only mods to my knowledge are aftermarket headers and dual exhaust . I think it's a stock cam . I have no knowledge of it having a tune .
They're pretty popular in the Mustang world. Since it was an easy plug & play on my'09, I bought one. Theory is it keeps your intake cleaner. Easy to empty the JLT one I bought, simply unscrews. Catches maybe a teaspoon or 2 of oil with each oil change. No negatives I can think of...(edit) Found an old thread on the JLT...a link:
https://www.imboc.com/threads/jlt-oil-separator-issue.204186/ Probably a better thread: https://www.imboc.com/threads/oil-catch-cans.308033/?post_id=3074785#post-3074785
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) Last edited by pwd72s; 02-10-2025 at 10:54 AM.. |
If you have crankcase pressure you need a catch can. It will keep out from buliding up on the throttle blades, the intake ports , valves and fowling spark plugs. My C6 has 102k miles and has no crankcase pressure. Never burns or leaks a drop. No catch can needed.
Keep talking, Im gonna put you in the trunk. |
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
I do look at it as a "Can't hurt, might help" thing. Like I said, on my 4.6 Mustang it was an easy plug & play thing...as simple as replacing the PCV hose using the factory clips...a no tool required thing. Dunno if it would be as easy with your LS. JLT did some good design work.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Don't have one on the LS2 on the Rumf.
Banned
On my carbed setup I have a catch can because the intake pulls a vacuum on the crank case for better ring seal. At least that is what the builder told me. Also keeps the system closed since tracks don't allow open breathers on the valve covers. For a modern engine it probably provides no benefit unless the rings are bad.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Kantry Member
Best Les
Best Les My train of thought has been replaced by a bumper car. |
Thank you that is very helpful .
My understanding it’s for diesels with blow-by.
If you’re still running an egr, it might be beneficial but i highly doubt you still have that bolted up.
dolor et pavor Copyright |
Retired Member
I have a bone stock LS7 as well. I don’t have a catch can, and I used to track the car. I never thought of getting one.
Saying that on the Corvette Forum some guys have them and there are vendors doing a booming business selling them. The used ones get snapped up as well There are threads on this topic over there.
80 911 SC sold 17 Tahoe 07 Z06 Corvette
I looked the engine over this morning , and you are correct the EGR has been eliminated . I have decided a catch can is not needed .
