Heat Reflecting Window Film
I have a former “sleeping porch” that was glassed in. It gets very hot in summer, and it’s not practical to AC.
I was thinking about using some window film to reduce the heat entering the room. Ideally without turning the room into a dark place, or making the house look like it has mirrors for windows. Have you used the stuff? How effective is it? Any tips for selecting the best stuff?
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? Last edited by jyl; 05-02-2025 at 07:51 AM.. |
Edministrator
I would talk to a local car window tinting place. You block heat by blocking infared, but you probably should block UV as well if you're going to be in there when the sun shines. I'm sure there's film for both, and (at least with IR), it can even be clear, although you'd probably want some tint to it.
Good post? Leave a tip! O - $1 O - $2 O - $3 |
Brew Master
3M makes several products just for this purpose. I haven't installed yet since the place where my son works hasn't gotten set up as a dealer yet. There are some kits you can buy on Amazon but I don't know how they stack up against 3M's product.
https://www.3m.com/3M/en_US/home-window-solutions-us/solutions/temperature-control/ There must not be much demand for it, but I've thought that having windows that work like Transitions lenses would be nice.
Nick Last edited by cabmandone; 05-02-2025 at 03:45 AM.. |
(the shotguns)
Can I add a question on this?
Does this sort of reflective film cause issues with double (or triple) pane windows?
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Brew Master
From my understanding, no it does not. It is supposed to improve their efficiency. Some double and triple pane windows come with a low e film installed. There are films that can be applied inside or outside depending on your preference. All the film is doing is reflecting IR and UV rays to reduce radiant heat gain in the home.
Nick Last edited by cabmandone; 05-02-2025 at 05:37 AM.. |
(the shotguns)
ok that's good to know. I guess I was wondering if that reflected heat wasn't overheating the sealed area between panes.
Did you get the memo?
I think Steve nailed it. I would look at a high quality ceramic tint that’s clear or very lightly tinted, they offer it typically for tinting windshields. I’ve tried it on a past vehicle and it was very effective at reducing the heat on sunny days.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Brew Master
Unless that heat is being retained, it shouldn't do any harm. And since that heat is passing through, it doesn't seem like it can be retained if it's diverted back out. And if concerned, use the exterior type of film so the reflection happens on the outside rather than allowing it to pass to the inner pane and then reflect out.
Nick |
I've wondered about something like this myself. I've installed tint before, it's easy. The hardest part is precision cutting it so it looks good and isn't obvious. THere are places where this sort of thing seems like it would be a huge improvement. It seems like from FL straight across to AZ at least, possibly SoCal. For stuff that's not in the deep south you may actually not mind some heat in the winter, so that would be a consideration for me.
Zink Racer
I have been following a thread in the tech section on electric AC. There is a lot of discussion there about various window film products to reduce cabin heat.
https://forums.pelicanparts.com/porsche-911-technical-forum/921754-classic-retrofit-lightweight-electric-air-conditioning-95.html
Jerry 1983 911 SC/Carrera Franken car, 1974 914 Bumblebee, 1970 914-4, 1999 323ti |
"Low E" window tint or film offers a lot of reduction to heat in sunrooms. The higher the reflectivity, the better the heat reduction.
We had a kitchen on the south side of the house with a lot of windows and no room for a practical awning for shade. It was so bright in that kitchen it looked like a Spielburg movie and it got hot in there every summer day. No amount of redirecting A/C airflow would solve it. Rather than reflective tint I added exterior screens that blocked 80% of the light and heat. I put them up in June and it greatly reduced summer heat and the overabundance of light in that room. You could still see fine through it as we did have a nice view of the city, but it reduced heat in the kitchen by 10*F. In October I would take down the screens, wash the windows and we benefitted by the light and heat gain during winter months. Just another option.
2009 Cayman PDK With a few tweaks 2021 Cayman GTS 4.0L 2021 Macan (dog hauler) |
Control Group
Put film from Home Depot on a bedroom window in my house. Room was definitely cooler.
How about a swamp cooler, or a redneck ice chest/box fam air conditioner?
She was the kindest person I ever met |
I'm putting minisplits in the bedrooms this month - including in the bedroom that the former sleeping porch is connected to. However, we need to keep the door from porch to bedroom closed most of the time for pet reasons.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Control Group
Those windows are designed for places without AC, let the heat out
Maybe sunshades outside the window, or trees to shade the area
Take longer than I’ll live to grow a tree that tall . . . and I don’t want to be installing and maintaining sunshades 30 feet above grade.
It’s going to be whatever windows film does - then blinds and/or AC for the hotter periods, which are thankfully still only a few months a year.
Brew Master
That's not exactly true. To the degree that a standard tinted film does nothing, yes that's true. But the films designed for residential and commercial windows have a stated U value and heat gain coefficient. The 3M P70X allows 70% of light to pass through, has a U value of 1.02, a heat gain coefficient of .48 and claims to reject 52% of total solar energy. I've really got to get this stuff bought and installed. It'll be fun checking floor and furniture temps (I have a sickness) to see what good it did.
Oh... and yeah a home energy audit is a wonderful thing. It helped me find where my worst air leaks were coming from and address them. I now have a home that is over 100 years old sealed to the minimum building standards of today which seems pretty good for an old home.
Nick Last edited by cabmandone; 05-03-2025 at 03:31 PM.. |
Edministrator
AI Overview
Learn more Window tinting can absorb a significant amount of infrared (IR) radiation, with many films boasting infrared rejection rates of over 90%. However, it's important to note that IR radiation only makes up about 53% of the total solar heat. Some films, like XPEL PRIME XR Ceramic, offer up to 85% infrared rejection. Other films, like the 3M Ceramic IR Series, can achieve up to 95% infrared rejection. According to a reddit user, 70-90% is a normal percentage for infrared rejection, and some products can reject up to 99% of infrared radiation. I googled "what percentage of IR is absorbed by window tinting"
Good post? Leave a tip! O - $1 O - $2 O - $3 Last edited by Steve Carlton; 05-03-2025 at 02:43 PM.. |
Edministrator
Sorry to be an armchair googler, but in my automotive glass experience, tint that is designed for reducing IR radiation (the kind that generates heat) is incredibly helpful. And it can be clear- tinting isn't a factor.
Well, I have some film coming and maybe it’ll do a little bit. I’m also going to figure out how to run AC hoses through that tilting window.
Edministrator
I'm happy to 'leave you alone.' Don't expect that to happen when you accuse me or others of ignorance or armchair googling.
