1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Brew Master
I would personally be very cautious about making any sort of surround to hide the outdoor unit. Messing with the airflow across the outdoor coil can affect both heating and cooling. Painting the outdoor unit to better blend in would by my first preference.
You mentioned flaring when you need to extend/shorten line sets. If you don't have a lot of experience in flaring copper, I'd recommend getting one and practicing a bit. A fair number of the leaks I've found on systems in the past have been at flare joints.
Nick Last edited by cabmandone; 05-05-2025 at 02:31 PM.. |
2009 Cayman PDK With a few tweaks |
Painting the outdoor units seems like the winning idea. You guys are right, I like the way my house looks and don’t want more baby livestock than necessary.
![]() ![]() I finally got started. Today all I’m doing is hanging the indoor units. To avoid cutting the molding, and make this an easily reversible install, I used 3/4” plywood to space the mounting point out from the wall and catch studs. My wife inspected the initial hung unit and her water has not broken, so I’m ok. She is surprisingly uncaring about mechanical and systems stuff, the baby cows emerge over a vase thoughtlessly repositioned or an improperly fluffed pillow. So of the two, I’m the one more bugged by the gap between unit and wall. Later on, I’ll find some easy way to fill or cover up that void.
![]() The lines will go through the closet to reach the exterior wall, and I’d like to fasten them up to the closet ceiling, protected and out of the way. So I’ll be adding a condensate pump to this room, and one other. I can power the pump from the indoor unit. Question: the hi and low pressure lines don’t care about the slope of lateral runs, correct? I.e. they can leave the indoor unit and go up before they exit the exterior wall and turn down?
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? Last edited by jyl; 05-18-2025 at 04:49 PM.. |
Also question - I’m seeing minisplit line sets (not pre-charged) at prices ranging from $270 for 25’ to $170 for 50’. Some have flares and nuts, others don’t, but I’m planning to cut to length and flare myself anyway.
Is there really a predictable difference in line quality between brands and sources? I am inclined to buy the cheapest linesets. I need four so the price diff can be $400 ish.
Ok your indoor register install doesn't suck
![]() My understanding is that slope matters for the condensate line to drain properly but not the copper lines. Your install instruction sheet should spell out any requirements or limitations.
Timely thread. I’m about to embark on this for the rental house. I’m going to use a ducted air handler in the attic so I can use one unit for a bedroom and bathroom.
Have you shopped Linesets from pioneer or Senville? They both get good reviews online and seem to have great prices. |
Brew Master
Nick |
What?!?!
That’s not horrible. Plus, no baby bovines braying about… winning!
running shoes, couple tools, fishing pole 1996 Subaru Legacy Outback AWD, 5speed 2002 Subaru Impreza WRX, 5speed 2014 Tundra SR5, 4x4 1964 Land Rover SII A 109 - sold this albatross |
Talking about minisplits: How good are they at heating, really ?
I got them in the new-old house... alongside old style radiators with a fuel burner! In summer, the minisplits were A-OK to cool down the house so I guess they were sized and distributed properly. Emboldened by that discovery and not loving the smell of the old fuel heater, we decided to get rid of the old fuel burner, the ecopper pipes all over, the radiators, and get more room and less smell.. Figured we could use the mini splits for heat... Then when the few colder winter days arrived we found we needed extra electric heaters here and there, because the mini splits struggled to heat the place "properly".. To be clear, not temperature wise but distribution wise... not sure it's "not enough of them" more like they are placed high up, when they shoot AC no issue, that goes down, but when they shoot warm air, it rises, and while I was not "cold" walking around the house, I could feel a significant temp difference from my ankles to my face and more chill sitting down, as if the high up mini split air was not reaching down low before it rose.. Gonna have to figure out a solution. Last edited by Deschodt; 05-23-2025 at 10:16 AM.. |
Ceiling fans?
Some s-l-o-w progress to report. Actually it was super slow until a bout of 95F lit a fire under my butt, and now I am seriously working on it.
Here is the north side, master bdrm on left and daughter’s bedroom on right. Decided on copper line covers, but won’t install those until the system is verified working. They’ll be like square section, about 8” wide, shiny for a while. They will go all the way to the eaves, to look better. People might think they are gutter downspouts. ![]() Cut lines to length at the outdoor unit and flared. I got what seems like a great flaring tool, the flaring cone moves eccentrically, and I put a dab of Nylog on it before starting the flare. ![]() Here is the south side, in progress. I plan to finish the lines here tomorrow. Access is a real pain, so much stuff to work around. Including the electrical service. I don’t love the idea of working right by and probably accidentally touching the electric service cables, who knows if the insulation is cracked, so I think I’ll drape them with a moving blanket or similar. ![]() I had to buy a 28’ ladder as my 20’ was way too short. With the spreader, and tied off to the house, the ladder is very stable. I didn’t like using both hands to torque the connections with none holding onto the ladder, but it worked. I’ve only dropped one wrench, and it wasn’t the torque wrench. When I go back up to install the covers, I’ll do a little paint touch up “while in there”.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? Last edited by jyl; 06-14-2025 at 05:44 PM.. |
![]() When I did the original PVC conduit ten years ago for the garage subpanel, I didn’t have an EMT bender. I think PVC conduit screams “DYIer” and I do have an EMT bender now. But I wanted the minisplit conduit to “match” the other one, so more DYI PVC conduit. Paint to come of course. ![]() I took the time to cut the conduit supports to fit the siding which is wonky there. ![]() The photo of the wiring is so I can review it for mistakes after a beer. ![]() I really regret not using my head and leaving more clearance - it’s a pain to work on the connections with the bumpout so close.
Very well done! I love the support you made, 99% would have just pipe clamped to the house. If you haven't, I would seal the support mounting surface so moisture doesn't get in between and stay there.
Tru6 Restoration & Design |
I think the clamps are supposed to retain the cable on the out core, to hold them up and prevent strain on the connections. I believe the wires should be clamped on the blue section below.
Plan B might be a zip tie above the clamp, the red lines. ![]()
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
(the shotguns)
that was my question as well!
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
![]() Range not big - 36” - but I wanted flexibility to put in a 48” someday. And to make a lot of smoke, steam, etc. Here I’m tossing cold water onto a hot oily pan to test the ventilation. Or I’m making potstickers.
Ah dummy (me). Thank you, I’ll fix that. There are strain reliefs/loom clamps where the cables enter the enclosure cover, but it would look better if the internal clamps were used too.
