How far away are you from Richmond or San Antonio?
https://houston.craigslist.org/tls/d/richmond-bench-grinder-inch/7833662219.html https://sanantonio.craigslist.org/tls/d/san-antonio-lot-of-miscellaneous-tools/7838890620.html
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Counterclockwise?
My other block.
Yes guys collect them and some have more than 2.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
My place to the westernmost edge of Houston - 55-60 miles downtown Houston 82 miles downtown Austin 82 miles And Houston and it's 'burbs are roughly 50 miles in diameter.
60 miles
![]() 60+ miles ![]() The one in Seally is probably only ~50 miles. The rest are somewhere in the 80 - 300 mile range.
Brew Master
Rather than buy a bench grinder, why not buy stock in the company that makes the blades for your mower? Seems like they might have a repeat customer which should keep sales going.
![]() I think you should buy every bench grinder you can find that seems reasonable, corner the market, then mark them up 10% making the last one free to you.
Nick Last edited by cabmandone; 05-07-2025 at 02:05 PM.. |
LOL! I'm using the "level 5" gator blades, I think.
Yep ![]() LOL! That sounds like a plan, corner the market on bench grinders, mark them up since there will be a low supply, and then flood the market at high prices until the price bottoms out. Folks will be using them as door stops by the time I'm done, and I'll be rich!
What I really need
Brew Master
I'd forget about trying to sharpen those with a bench grinder. That downward drop spells doom. That's straight up an angle grinder job IMO.
Nick |
Control Group
You need to hit an estate sale with tools
She was the kindest person I ever met |
Thank you. I'll never go back to the grinder again. It's faster, easier, and does a better job. It doesn't seem to heat the blade as much, I think because the friction isn't localized like it is on a grinding wheel. It's easy to keep a nice, flat angle, too. After I did the first one, I got out all my old blades and resurrected them. I had a couple of blades that had big chunks knocked out of them. Used the grinder to square off the edge until I got a straight edge without any missing places, and put a sharp edge on it with the angle grinder. Thanks for this tip. Another win for PPOT. ![]()
You guys were right. The angle grinder with a flap disc is a VERY quick and easy way to sharpen mower blades!
Its because an angle grinder runs at like 3x the rpm of a bench grinder. I wouldnt suggest buying gator blades. When they get old those fins break off and throw off the balance so you dont get as much life out of them.
82 SC , 72 914 |
