Air Medal or two
I have had all sorts of broken bones, and last spring I herniated a disk.
The pain in the leg was so, SO bad I could almost not walk. After much research, I discovered that the disk protrudes out into the S. nerve. This is the cause of the pain dwn the leg, the burning, the loss of use, the numbness on the top of the foot. The good news in a high percentage of these types cases, the body will slowly eat it up. It did. ( I guess?) That it would take a few months and a LOT of pain pills to survive. I still have limited use of the right foot, but getting better, and the pain is 90% gone too! Moral of the story- don't get in a hurry to get under the knife! At least with a Hurnated disk.
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. Last edited by afterburn 549; 05-27-2025 at 04:43 PM.. |
Brew Master
^^^ Look up the "Cobra pose" and do it but not to the point where it hurts. Work gradually towards full arm extension. I think the one for the piriformis is called the pigeon pose. There's a variation where you lay on your back, put your left ankle on right knee and pull the right leg towards your chest. You can also so something similar from a sitting position leaning forward towards the leg. The pigeon pose is "advanced" but it's the one that helps me the most when I have a flareup. Another good stretch that I've used is taking a broom stick, holding it at the base of my neck and waistline, facing a set of stairs I put my heel on about the second stair and gently lean forward using the broomstick to make sure my spine stays neutral. This stretches the hamstring and calf. Remember to always warm up a bit before stretching.
Nick Last edited by cabmandone; 05-27-2025 at 06:09 PM.. |
When the pain goes beyond my threshold, will take them. One of the reasons I am looking to change Pain management doctors, for my back and knees, I want pool exercises physical therapy, and he ask me if I have been taking the pain medicine he prescribed, then noticed that I never had the pain pills prescription filled.
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
There is a thread here, “greetings from the Kettering …”. It’s about my experience with back surgery. You might want to look through it.
And/or do yoga a couple times a week. It will transform your back for the better over time. Sent from my CPH2451 using Tapatalk |
Control Group
I would talk to a witch doctor about voodoo treatment before I would get back surgery I kid, sort of Your spinal column is kinda complicated https://teachmeanatomy.info/back/bones/vertebral-column/ It moves sort of like a rope made out of a stack of bone blocks(vertebrae) with gel shock absorbers(intervertebral discs) between them, with gel prevented from leaking out by a fibrous wrapping that contains the gel. The spine is pretty straight, or should be from the front; if you look at it from the side, it is curved, because the bone blocks are semi wedge shaped. Behind the bone/shock absorber column is a roughly triangular shaped space with little struts of bone that stick out the back and to either side of this triangular shaped space. The little struts are where the muscles attach. Looking at a vertebra from the top, you have a sort of round bone, that has this pieces sticking out the back that forms the triangular shaped space that carries the Spinal Cord, which is all the nerves coming out of your melon like a big cable that has smaller cables coming off at each vertebral level. Each of these nerves is often bundled with nerves from the level above or below to form larger nerves, which is the deal with your sciatic nerve, which is like 4 or 5 levels of vertebral nerves bundled together and runs from your lower back to your foot, with the nerve getting smaller as it goes down your leg and gives innervation to structures along the way. This nerve is big as one of your fingers in your lower back/ass, and can get hung up at a number of different levels. For example, you can have a tight piriformis muscle and it compresses the sciatic nerve, giving you screaming pain down the back of your leg that is quite incapacitating. You can also have an intervertebral disc herniate posteriorly and impinge on the spinal cord. First thing is to figure out what is causing the symptoms. Surgery is what you think about when all the conservative measures have failed and your quality of life is crap.
She was the kindest person I ever met |
Honestly, the pool helps me a lot and that is why I keep telling my pain management doctor that I prefer aqua PT over pain pills. And the latest X-rays show lots of damage, and most arthritis, something they say nothing can be done about. I’m tired of living in pain, but I have responsibilities and my elderly Mother counts on me, as does the feral cat colony I feed. If I wasn’t needed for those, I’d probably just say screw it. Seriously, I’m tired of the pain, tired of the so called friends who don’t do what they say or only hear from them when they need something, just flat out tired or not being physically able too do what I used to do with ease.. The old man in Logan’s Run had it right.
Air Medal or two
They also gave me a stack of steroids.
My usual mindset is to stay away from meds. In this case there was SO much pain, if they had set a bowl of pig poop if front of me , and said this will help, I would have eaten it !!
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
A 90/90 stretch is also useful and maybe easier to get into. Sit on the floor, make sure you do along side a chair or something else to help you get back up if you think you’ll need it. Put one leg in front of you bent at the knee to 90 degrees, the other behind you also at 90. Sounds more difficult than it is. Google for pictures or videos. Using your arms to control the movement, lean forward letting your upper body weight aide in the stretch. Hold it for a couple moments and then back up and repeat for 30 seconds. Switch leg position and do it again for the other side. Leg swings both front to back and side to side (30 seconds each for a total of 2 minutes) are an easy warm up to get the blood flowing. Again google for pictures or videos. |
Control Group
Pool therapy is the cat's ass for you old heads
My buddy called me earlier ... he had just had his initial visit with the place Byron recommended. Another visit scheduled for Sat. morning.
Attitude wise .... he was my 40 year long friend today ... not "that guy" I talked to a few days back. Time will tell ... but he was in a totally different mood today .... just his whole perspective. I just can't thank you guys enough ... for me or him! Pain sucks .... Best to you Byron. |
Control Group
Now maybe Byron can find him a few dancers to date
Brew Master
Nick |
I was in back and leg pain for over two years. The crappy Canadian health care system could only tell me that I had a degenerative spinal condition, no reason for my quads and knees to give out. I went to my place in AZ got an MRI (9+ month wait in Canada). The good American doctors took two days to diagnose me with spinal stenosis in the lumbar. They still couldn't tell me why my legs were messed up.
Long story short, after some research I got an inversion table and in less than two months I'm pretty much back to normal. In addition to 10 minutes/day of inversion I try to do 45 minutes of stretches and old man exercises and about 1 hour of walking every day. I also take extra protein. I'm an inversion therapy apostle now. |
I posted a thread here many years ago about sciatica misery. I won't link it here because I was in such pain I sounded pathetic. My right leg was numb, and I dragged that leg trying to walk. I spent many nights in a hot bath drinking huge volumes of liquor combined with Vicodin pills. I was ready to kill myself to end it all. That lasted 2 months until my body started to heal. I had an orthopedic doc try to make some adjustments, but they did not work. I took the recommendation of a local acupuncture guy and after the first visit I was in much less pain. Success! NOPE, my second visit he got more serious with the needles and I was literally crying in agony. I had to crawl out of his office on my hands and knees. It was quite the spectacle.
The only relief I got was standing upright. Not so good when you are wasted and have no sleep. I tried pool therepy and was comfortable hanging on the edge until one leg went a few degrees to far and made everything much worse. Repeat the crawl spectacle this time out out of the gym pool. In the end nothing really helped much. I found a chiropractor that focused on minute adjustments that after 10 sessions or so started to help. I found ice to be horrible and went with heat in the pain areas. A few more weeks and I got feeling back in my leg/foot and no longer needed pain killers (booze/pills). I started a slow regimen of core body exercises using my own body weight and have been mostly pain free since...going on 15 years or so. I am getting older and it's just a matter of time until I lift a coffee cup and it all comes back to haunt me again. Far too many injuries in my youth and middle years that I cannot overcome. So my suggestion is once you get the sciatica pain under control focus on core strengh training. In my case that really worked and continues to work. |
Air Medal or two
I am happy that you and I got better! ^^
Pain still haunts me as I have done way too much abuse to this back. Standing for long kills me, but the rest of it is Ok compared to where I was!
I've been migrating from my 2015 MAC to a new one...cleaning up files and links, etc. and I found this older link:
https://www.silversneakers.com/blog/sciatica-stretches-exercises-ease-pain-seniors-2/ I never became a "Silver Sneaker", but the info and exercises are good
1996 FJ80. |
