What's the length of this rope
or, umm, wire. Need to get these on FBMP. I'm not unraveling and measuring.
Tru6 Restoration & Design |
Parrothead member
On the spool, can you read the markings on the end sticking out of the hole?
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
Markings on the wire Vinny? Yes, they are what you see in the third pic. My guess is at least 60% of the spool is gone.
There was 500 lineal feet on the wooden spool, but it’s used, so no telling how much now. Maybe 100’ now?
On the Romex, the box says 250’ if not used. |
Thanks, box is used too.
Parrothead member
Shaun check if you can see the footage marking near the end by the center hole if possible, then check the footage marking on the loose end.
Cut a foot
Weigh it Calculate length based on weight after subtracting an estimated weight for the spool. Alternately, remove the spool for a more precise measure |
First thing I do tomorrow, thanks, now I get it.
THat is a really good idea, thanks. I think it will only work for the box, can't imagine what that spool will weigh.
Platinum Member
Count the coils, multiply by pi*d
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Parrothead member
Normally when it's spooled like that, it's starts at zero ft, then is marked as it is loaded on. The last ft marking on the loose end is most likely the actual footage left on the spool.
I thought about that and it would be easy for the wire in the box. For the wire on the spool, there would be more work involved.
Twice the distance from its midpoint to its end
Platinum Member
By the way Shaun, that white awg12 may come in handy some day. Especially if you want to make a new 'repair' in an older house look like it was existing.
The low voltage spool has feet marked on it, I can see 278ft on a section and 250ft on another, so check both ends and do some math.
Rutager West 1977 911S Targa Chocolate Brown |
Thanks, I thought of that too for the box but I really like the weigh 1 foot idea as well given the variable diamaters.
Good eye Rutager, thanks.
MAGA
Per Google...
12/3 romex weighs .107 lb/ft. 14 AWG 2/C E57497 unshielded weighs .037 lbs/ft typical plywood weigh about 35 lbs per cubic foot
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Measure diameter of outer coil, estimate diameter of arbor, take average of those diameters as D, divide half the difference in diameter by diameter of one wire as N, count number of coils visible on surface as C, (2 * pi * D/2) * N * C is estimated length of wire.
Do all of the methods discussed in thread and let us know what the results are and what the actual length is.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Parrothead member
Or you could just look the the footage printed on the cable......
