Air Medal or two
afterburn 549's Avatar
Ultrasonic cleaner choice
Ultrasonic cleaner choice-
Does anyone have a recommendation as to what works well and is simple?
I would like at least 30 inches in length.
This will allow most of my motorcycle, car parts to fit in the broth.
Thanx!
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 08-20-2025, 09:42 AM
30" long is huge, AB!
I bought a Creworks brand 6L (6 liter) size off eBay about a year and a half ago for around $100 that I use for my motorcycle stuff - mostly brake and carb stuff - that does the job for me.
It only has a 12" tank length.
Even their 30L size only has a 20" tank length.
Others here will add input, I'm sure.
Good luck!
Old 08-20-2025, 10:58 AM
Air Medal or two
Thanx, I would like a minimum of 30 inches.
I could get lots of different stuff in there !
Old 08-20-2025, 11:05 AM
faverymi's Avatar
A 30 inch wide ultrasonic fits into the industrial size category.
Look at what Grainger it's offering. You are going to get a sticker shock
You may want to adapt or look at what is used on CL of FB
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 08-20-2025, 11:06 AM
unsafe at any speed
wswartzwel's Avatar
I bought a DK Sonic off amazon 6 or 7 years ago. I own a powersports repair business, and use it almost daily cleaning carburetors and small parts. Mine holds about 5 gallons. I use a mixture of water, pine sol, and simple green. carburetors come out nice and shiny.
Bill Swartzwelder
Old 08-20-2025, 11:09 AM
Hey Bill....if you don't mind......could you please share the mixture rate you are using with those 3 ingredients? Thanks!
Old 08-20-2025, 11:43 AM
Platinum Member
dad911's Avatar
You may want to keep your eyes on gov surplus auction sites for something that big.
Old 08-20-2025, 12:39 PM
Home of the Whopper
Don't get plastic!
My lid melted!
But I was using carb cleaner.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 08-20-2025, 12:56 PM
Air Medal or two
Width for me is not too important, Most of my parts are longer and narrow.
Old 08-20-2025, 01:06 PM
Platinum Member
dad911's Avatar
I wonder if you could hack the guts out of a cleaner and strap it to a longer stainless tray.
Old 08-20-2025, 01:23 PM
Air Medal or two
IF, If I can't find anything, I will consider your idea~!
So far, not much out there.....
Old 08-20-2025, 02:20 PM
Arizona_928's Avatar
These look to be 20 inchers.
https://www.vevor.com/ultrasonic-cleaner-c_11064/vevor-10l-ultrasonic-gun-cleaner-300w-ultra-sonic-cleaner-timer-heater-basket-p_010684341307
dolor et pavor
Copyright
Old 08-20-2025, 02:54 PM
May not be helpful - but on larger items I tend to use a water soluble degreaser soak and then a wire brushing. In some cases where rust is an issue a soak afterwards in Evapo-Rust. I'll also used water blasting from garden hose and/or power washer - and that will help knock a lot of stuff off the part.
Using this method you would simply use a large tote to hold the soaking fluids.
Here's a 45 gallon tub I use. In this situation it was for a motorcycle tank. Sucker is 30" long so needed something big!
The exterior was fine - it was the interior that needed help. I filled her with Evapo-Rust and let it soak for a few days. The tub was to contain anything that may have leaked out. Hate to lose any Evapo-Rust because it's not cheap!
Old 08-20-2025, 03:01 PM
unsafe at any speed
wswartzwel's Avatar
4 gallons water. 1 pint of pine sol. 1 pint of simple green
I also have a hot water heater element wired and sealed on a extension cord that i drop in to heat the water up more quickly... but that could electrocute a guy if you are not careful.
Bill Swartzwelder
Old 08-20-2025, 03:07 PM
Thanks, Bill - really appreciate it.
It does take a while on my small (6L) unit for the temp to get up where I want it....but on your larger unit....I can totally understand your improvised method of getting it up quicker - very nice!
Old 08-20-2025, 03:36 PM
Model Citizen
herr_oberst's Avatar
35" wide, Free shipping.
http://www.jbtools.com/raytech-turbosonic-power-pro-ultrasonic-cleaner-115v-7631734r/?wi=off&gad_source=4&gad_campaignid=22171588440&gbraid=0AAAAADsRHpNeoZK_l7DqPW0pwhIjxGPxR&gclid=Cj0KCQjw5JXFBhCrARIsAL1ckPtj8vFCI-HxlkIgG_E0NeRY4SSxmNarFK1Qm2yCsipe27XiM9vj494aAiMC EALw_wcB
Old 08-20-2025, 04:20 PM
that's a very fair price. I've paid double that for a smaller thermo lab one.
dolor et pavor
Copyright
Old 08-20-2025, 04:39 PM
Old 08-20-2025, 06:57 PM
Air Medal or two
Thanx Herr Oberst.
I have seen a couple in that neighborhood of $$$$
I am boiling things dwn to final results here........( LOL)
Old 08-21-2025, 02:28 AM
(the shotguns)
berettafan's Avatar
thinking back to my younger days here....could you just put the stuff in a tub then get in and fart in the tub?
you'd have to do a lot of farting to be effective but cost would be minimal.
Old 08-21-2025, 05:05 AM
