Air Medal or two
Ultrasonic cleaner choice
Ultrasonic cleaner choice-
Does anyone have a recommendation as to what works well and is simple? I would like at least 30 inches in length. This will allow most of my motorcycle, car parts to fit in the broth. Thanx!
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
30" long is huge, AB!
I bought a Creworks brand 6L (6 liter) size off eBay about a year and a half ago for around $100 that I use for my motorcycle stuff - mostly brake and carb stuff - that does the job for me. It only has a 12" tank length. Even their 30L size only has a 20" tank length. Others here will add input, I'm sure. Good luck!
Old dog....new tricks..... |
Air Medal or two
Thanx, I would like a minimum of 30 inches.
I could get lots of different stuff in there !
A 30 inch wide ultrasonic fits into the industrial size category.
Look at what Grainger it's offering. You are going to get a sticker shock You may want to adapt or look at what is used on CL of FB
RSA Pinky Helga Turtle Carrera Luigi CDtdi |
unsafe at any speed
I bought a DK Sonic off amazon 6 or 7 years ago. I own a powersports repair business, and use it almost daily cleaning carburetors and small parts. Mine holds about 5 gallons. I use a mixture of water, pine sol, and simple green. carburetors come out nice and shiny.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
Platinum Member
You may want to keep your eyes on gov surplus auction sites for something that big.
Politics is in the eye of the beholder - Rodney Dangerfield |
Home of the Whopper
Don't get plastic!
My lid melted! But I was using carb cleaner.
1968 912 coupe 1971 911E Targa rustbucket 1972 914 1.7 1987 924S |
Air Medal or two
Width for me is not too important, Most of my parts are longer and narrow.
Platinum Member
I wonder if you could hack the guts out of a cleaner and strap it to a longer stainless tray.
Air Medal or two
IF, If I can't find anything, I will consider your idea~!
So far, not much out there.....
These look to be 20 inchers.
https://www.vevor.com/ultrasonic-cleaner-c_11064/vevor-10l-ultrasonic-gun-cleaner-300w-ultra-sonic-cleaner-timer-heater-basket-p_010684341307
dolor et pavor Copyright |
May not be helpful - but on larger items I tend to use a water soluble degreaser soak and then a wire brushing. In some cases where rust is an issue a soak afterwards in Evapo-Rust. I'll also used water blasting from garden hose and/or power washer - and that will help knock a lot of stuff off the part.
Using this method you would simply use a large tote to hold the soaking fluids. Here's a 45 gallon tub I use. In this situation it was for a motorcycle tank. Sucker is 30" long so needed something big! The exterior was fine - it was the interior that needed help. I filled her with Evapo-Rust and let it soak for a few days. The tub was to contain anything that may have leaked out. Hate to lose any Evapo-Rust because it's not cheap!
unsafe at any speed
I also have a hot water heater element wired and sealed on a extension cord that i drop in to heat the water up more quickly... but that could electrocute a guy if you are not careful. ![]()
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 Last edited by wswartzwel; 08-20-2025 at 02:13 PM.. |
It does take a while on my small (6L) unit for the temp to get up where I want it....but on your larger unit....I can totally understand your improvised method of getting it up quicker - very nice!
Model Citizen
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
that's a very fair price. I've paid double that for a smaller thermo lab one.
Air Medal or two
Thanx Herr Oberst.
I have seen a couple in that neighborhood of $$$$ I am boiling things dwn to final results here........( LOL)
(the shotguns)
thinking back to my younger days here....could you just put the stuff in a tub then get in and fart in the tub?
you'd have to do a lot of farting to be effective but cost would be minimal.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Thread Tools | |
Rate This Thread | |
