Air Medal or two
Ultrasonic cleaner choice
Ultrasonic cleaner choice-
Does anyone have a recommendation as to what works well and is simple? I would like at least 30 inches in length. This will allow most of my motorcycle, car parts to fit in the broth. Thanx!
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
30" long is huge, AB!
I bought a Creworks brand 6L (6 liter) size off eBay about a year and a half ago for around $100 that I use for my motorcycle stuff - mostly brake and carb stuff - that does the job for me. It only has a 12" tank length. Even their 30L size only has a 20" tank length. Others here will add input, I'm sure. Good luck!
Old dog....new tricks..... |
Air Medal or two
Thanx, I would like a minimum of 30 inches.
I could get lots of different stuff in there !
A 30 inch wide ultrasonic fits into the industrial size category.
Look at what Grainger it's offering. You are going to get a sticker shock You may want to adapt or look at what is used on CL of FB
RSA Pinky Helga Turtle Carrera Luigi CDtdi |
unsafe at any speed
I bought a DK Sonic off amazon 6 or 7 years ago. I own a powersports repair business, and use it almost daily cleaning carburetors and small parts. Mine holds about 5 gallons. I use a mixture of water, pine sol, and simple green. carburetors come out nice and shiny.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
Platinum Member
You may want to keep your eyes on gov surplus auction sites for something that big.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Home of the Whopper
Don't get plastic!
My lid melted! But I was using carb cleaner.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
Air Medal or two
Width for me is not too important, Most of my parts are longer and narrow.
Platinum Member
I wonder if you could hack the guts out of a cleaner and strap it to a longer stainless tray.
Air Medal or two
IF, If I can't find anything, I will consider your idea~!
So far, not much out there.....
These look to be 20 inchers.
https://www.vevor.com/ultrasonic-cleaner-c_11064/vevor-10l-ultrasonic-gun-cleaner-300w-ultra-sonic-cleaner-timer-heater-basket-p_010684341307
dolor et pavor Copyright |
May not be helpful - but on larger items I tend to use a water soluble degreaser soak and then a wire brushing. In some cases where rust is an issue a soak afterwards in Evapo-Rust. I'll also used water blasting from garden hose and/or power washer - and that will help knock a lot of stuff off the part.
Using this method you would simply use a large tote to hold the soaking fluids. Here's a 45 gallon tub I use. In this situation it was for a motorcycle tank. Sucker is 30" long so needed something big! The exterior was fine - it was the interior that needed help. I filled her with Evapo-Rust and let it soak for a few days. The tub was to contain anything that may have leaked out. Hate to lose any Evapo-Rust because it's not cheap!
unsafe at any speed
I also have a hot water heater element wired and sealed on a extension cord that i drop in to heat the water up more quickly... but that could electrocute a guy if you are not careful.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 Last edited by wswartzwel; 08-20-2025 at 03:13 PM.. |
It does take a while on my small (6L) unit for the temp to get up where I want it....but on your larger unit....I can totally understand your improvised method of getting it up quicker - very nice!
Model Citizen
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
that's a very fair price. I've paid double that for a smaller thermo lab one.
Air Medal or two
Thanx Herr Oberst.
I have seen a couple in that neighborhood of $$$$ I am boiling things dwn to final results here........( LOL)
(the shotguns)
thinking back to my younger days here....could you just put the stuff in a tub then get in and fart in the tub?
you'd have to do a lot of farting to be effective but cost would be minimal.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
