Oh yeah, and what is the race car? A Radical or(?)
Sooooo.... just what are you building next :D? Thank you for raising the bar so high I can limbo under it standing up... Easy-peasy :) |
Goodness. |
Budget? Gotta ask.
Most people have skill, time, or money. Rarely all 3! |
When I think of all of the things that go into the design and construction of an RV, it's a vehicle and a house on wheels. Water, electric, (usually two different systems), waste, HVAC, etc., etc...
What a rig. :cool: |
To the OP: what is your day job ?
The fresh water location was a bit tricky. I didn't want to go the easy route as RV mfg do by using valuable bay space, so I opted to mount it under the bed. You can see it in the picture. I did not finish it yet as I want to use it for a bit to make sure it doesn't leak. http://forums.pelicanparts.com/uploa...1756233094.jpg |
rrental- first, this an amazing build. I'm thinking that if you had filmed the build and edited it for youtube you would have had a LOT of subscribers. Nice stuff.
I see a lot of manufactured Toterhomes out at the track; are you planning to build a companion trailer to carry tools, tires, fuel, workbenches etc etc when you go racing? |
Thank you all for the amazing comments. I am humbled by it. This forum is a great place and inspiration for me.
The good thing when building my own motorhome is that I can put the effort and recourses in area's that are important to me. Practicality, ease of use and reliability was my main focus. For example, a fully tiled shower looks awesome, but it adds weight and more chance of leaks etc. So I opted for a simple fiberglass one piece shower stall. Or a vinyl finished floor instead of tile. Again, reduced weight and I haven't seen a single motorhome yet without cracked tiles and grout. Instead I focused on using higher quality marine products as much as possible, and serviceability. Here are some pictures of the more technical part of the project. For low voltage system I opted to go 24 Volts with some 24v-12v converters for the house part. This makes a more efficient system. The complete system is remote monitored through the web (Starlink) and setup with over/under charge alerts, geofencing etc. Pretty cool what can be done these days. All the light controls are switched with a Canbus sytem, so the lights, HVAC etc can be controlled from anywhere in the coach. Handy to switch off the living room lights from the bedroom! The heating system is a diesel powered heat exchange system. This will give instant hot water, and heat exchangers independently regulated per area. (living room/bathroom and garage) The coach has 3 air conditioners. 2 in the living room and 1 in the garage. The are all ducted together, so we can run the garage air conditioner, close all the registers there and have cold air in the living room without the noise. On a good sunny day the solar will provide enough power to run one air conditioner without depleting the batteries. If we run more than 1 at the time we need to start the generator. For the wiring, I can pull a wire at any time from the front to the back of the coach. All the wiring above the frame is located above the cabinets in the living room and the garage and goes to a central hub in the bathroom. Sorry to be nerding out a bit here..... http://forums.pelicanparts.com/uploa...1756235022.jpg http://forums.pelicanparts.com/uploa...1756235022.jpg http://forums.pelicanparts.com/uploa...1756235022.jpg http://forums.pelicanparts.com/uploa...1756235022.jpg http://forums.pelicanparts.com/uploa...1756235022.jpg |
Nerd away, my friend. We are your kind of people!
I stayed in a Holiday Express once :D
That's one of the most impressive builds I've seen here (or anywhere). Outstanding.
Super impressive. Congratulations on completing this project. I've got huge respect for your fabrication skills. I've been sort of thinking about something similar but starting with a 20' aluminum v-nose trailer. I've been amazed at how many 24' "toy haulers" have only a 10' or 11' "garage". Does no one want to carry an actual car in one of these things? Only quads or bikes? My challenge is that I want to drive an aircooled 911 in a lot of places around the US but there is no way the wife will ride in one for more than a couple hours. PLUS she doesn't want to be in a transport vehicle with another car in the same space. She's worried about fumes and fires, etc. etc. so a toy hauler like you've built is out too :( I don't need a huge living area cuz this misses ain't camping out for maybe one or two nights max. And that is at a plush campground with hot showers and flushing toilets. Just need a compartment for a bed, small TV, coffee maker, microwave, sink, fresh and gray water tanks. I'm leaning towards converting a trailer into 14' garage area and 6'+ the V nose for the living/sleeping area. Anyway, congrats again.
I’m feeling the similar sense of despair I get watching some on YouTube play a guitar. Like throw my guitar out despair.
Amazing build. The amount of decisions and product sourcing and knowledge here is staggering. |
Do you have plans to build another one?
| All times are GMT -8. The time now is 07:19 AM. |
