Shaun @ Tru6's Avatar
Homemade power cord for deep fryer
Seem to have lost the power cord for my Krups deep fryer. I can get a replacement but thought I could make one from an extension cord and 10-12 butt connectors. The fryer has 2 posts that join to 2 posts in the cord, magnet holding them together. I think a 10-12 connector will fit over the posts on the fryer console.
Thoughts?
cord connector
Tru6 Restoration & Design
Old 10-12-2025, 06:35 AM
Just had spade connectors. Seems to work. Good day for fried chicken.
Old 10-12-2025, 07:01 AM
Paper Member
Looks good to me. Enjoy your dinner
Enemy of the State
Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it.
Old 10-12-2025, 07:47 AM
Model Citizen
herr_oberst's Avatar
Necessity is the mother of fried chicken.
Old 10-12-2025, 08:01 AM
Here's a huge plus. The magnetic power cord took forever to get the fryer to 350-375ºF. For whatever reason, it now heats up in well under half the time.
Old 10-12-2025, 10:06 AM
rfuerst911sc's Avatar
Does it say anywhere on the unit how many amps/watts it pulls ? That would be my only concern . Otherwise just keep an eye on the wires and crimp connectors to make sure they don't overheat . Looks good to me.
Old 10-12-2025, 10:15 AM
I can look. It heats up 10-12 lbs of tallow/lard, 1.75 gallons of oil, so it must have a healthy draw. Good advice on keeping an eye on everything. And for obvious reasons, I never turn it on and leave the kitchen. Always prepping while it's working.
Old 10-12-2025, 10:19 AM
Zeke's Avatar
I think you just made a good case for hard wiring that. Connections have resistance. YMMV.
Old 10-12-2025, 11:04 AM
Platinum Member
dad911's Avatar
2 wire, no ground, metal appliance..... no worries.
If you have a voltmeter, measure everything metal on that to ground with it plugged in and on.
If you have an ohmmeter, measure metal to both prongs, with it off and unplugged.
If you have neither, put some water in the sink, stick one foot in the sink, and touch everything metal on the fryer....
Edit: Perhaps that metal center area on the plug/socket is the ground? With it unplugged, measure continuity from that to the metal parts on the fryer.....
Old 10-12-2025, 12:16 PM
Zeke's Avatar
@dad911, good point on the magnetic attaching as a ground. That's a poor ass way of doing it, but something is better than nothing. We have to remember, electricity ALWAYS takes the path of least resistance. I want my grounds hard wired.
But it could be a double insulated appliance. It seems most are. In order to know, we need to see the other end of the cord.
Old 10-12-2025, 01:12 PM
Original power cord is only 2 prong.
The control box and heating element with thermostat are completely isolated, that is they float on and in a square open frame sits on plastic feet and has a plastic mount on the back of the frame. A metal tin goes into the frame in which the heating element is submerged in tallow/oil.
Old 10-12-2025, 02:38 PM
Band.
Looks just fine
It's probably 1500-1800 watts so just make sure that cord is 12awg or something or else it'll get a little melty
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 10-12-2025, 03:06 PM
No idea on the model of your fryer, but it looks like a representative Krup part costs under 5 bucks.
I'm as cheap as the next tightwad, but I think in this case I'd spring for it.
EDIT: there's a bunch of them on amazon, but it looks like $14 is a more typical price.
Old 10-12-2025, 03:43 PM
Fried chicken was a big success as was the warm bacon vinaigrette spinach salad though the roasted chestnuts needed to be soaked overnight, who knew. Double frying a lot of thighs, drumsticks and wings, the new wiring was a godsend for keep the tallow at temp.
Old 10-13-2025, 03:14 AM
vash's Avatar
nicely done.
i have taken a cord to a lamp repair shop and had one rebuilt before.
for the fryer, i know most units come with a special cord attachment that comes undone easily if you trip or somehow hit the cord. it lets go easily so you dont send hot oil flying on a bad move of feet or hands.
just a thought
poof! gone
Old 10-13-2025, 09:06 AM
greglepore's Avatar
nicely done.
just a thought
Didn't think of that, makes a lot of sense.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 10-13-2025, 09:17 AM
nicely done.
just a thought
You are correct, fryers have easy breakaway cords, even with very short countertop only cords where an accident isn't very likely, but lawyers and stupid people I guess. I was lucky then to only have the shielded spade connectors. A butt connector snugly over the post probably wouldn't breakaway easily, it would likely snag and hold. The spade connector is basically light friction holding the spade against post. It breaks away very easily but provides better current draw. Not something a MFG could do but for me, it will work well.
Old 10-13-2025, 10:10 AM
Zeke's Avatar
I had forgotten the break away thing. IDK, I have mixed feelings. Short cord, yes. The no longer under the island or peninsula counter receptacle that allowed and errant knee or child to catch the cord, yes again. In the long run, I think the newer codes are wise.
But the spade connections are better for resistance, that I agree with. AFA easily detached, maybe not so much. I don't suppose you'd ever sell it so no worries unless you have an incident in your own home.
A good wake up call for us that grew up without bicycle helmets.
Old 10-13-2025, 10:42 AM
Platinum Member
dad911's Avatar
Are those spade connectors exposed when they come out?
As in, knock it over, spark from cord catches hot spilt flammable grease on fire.............
Old 10-13-2025, 11:14 AM
Zeke's Avatar
Generally the insulated spade connections, at least in my kit, extend past the metal part. That would be the female.
I wanna know how he got the flat connector on a short round terminal.
Old 10-13-2025, 11:25 AM
