Band.
Yellow PTFE on petcock threads?
Hello
I'm having trouble with weepy petcock threads on my 1972 Triumph Tiger and I would like to put some Yellow PTFE or Gasolia tape on there. Brand new petcocks, recently cleaned tank, brand new Dowty sealing washers everywhere. All the old boyz in the bike forums say that yellow PTFE is great or that the bike will immediately self destruct just on the mention of it, so I figured it would be fun to see what you say. What do you say?
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Slippery Slope Victim
In my former work world Yellow tape was for natural gas. We only used Rectorseal No. 5 on gasoline of fuel oils. In my experience (47 years in industrial / commercial plumbing) sometime PTFE can be too slick and the fitting can be made up "too tight" and be in danger of damaging either the fitting or the female item being threaded into.
Cheers
Mike˛ 1985 M491 Last edited by NY65912; 11-24-2025 at 03:51 PM.. |
Retired Member
Teflon tape should work, just wrap it once. Pipe dope should work as well
80 911 SC sold 17 Tahoe 07 Z06 Corvette
What thread size is it 1/8" or 1/4"? If it is 1/8" better to use the white teflon tape, just keep it back from the first thread, only difference between white or yellow is thickness of tape. You said all the parts are new so no chance that somebody used a NPT fitting into a BSPT thread.
87 930, Last edited by 908/930; 11-25-2025 at 09:34 AM.. |
Home of the Whopper
Connecting to female plastic threads?
If so good luck! Over tightening is the biggest issue. Use good pipe dope!
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
I have found Seal All brand sealant, available at most auto parts stores, to be absolutely gasoline proof. I have even used it to seal an actively dripping puncture in the bottom of a buddy's early 911 gas tank after one of our typically ill -advised off road adventures when he bottomed out. I used it to seal the seam between the upper and lower halves of the carbon fiber gas tank on my Ducati after ethanol enhanced gas ate through whatever was originally used. It's soft enough to allow you to take things apart later if you need to as well. Good stuff.
Band.
No, metal. No worries there.
Band.
