-   -   need to make a cabinet ⅛" more narrow - possible? (http://forums.pelicanparts.com/off-topic-discussions/1186734-need-make-cabinet-more-narrow-possible.html)
masraum 11-30-2025 07:39 PM
Ok, planer is in the mail, should arrive Wed!
masraum 11-30-2025 07:41 PM
Originally Posted by gregpark (Post 12571432)
Remove and re-install the stone counter top? you'd be replacing it (possibly along with the back splash which sits on top). The stone is most likely glued down with blobs of epoxy for fine tune leveling upon install. It will come out...but in pieces. And no need to destroy the cabinet (which you would by banging it apart). Typically the face frame of the cabinet protrudes into the stove opening a half inch proud of the body of the cabinet. The fastest and easiest way of widening the existing opening with no risk is to shave the face frame and grind the edge of the top all done on one side of the opening
The cabinet face and side and stone are all essentially flush on both sides. I definitely do NOT want to try to remove the stone from the cabinet unless I absolutely have to.
And before I tried to disassemble the existing cabinet, I'd just make a new one.
gregpark 11-30-2025 07:44 PM
You'll learn to love it. It takes some practice but a hand held power planer saves so much time on so many projects and is dead on accurate when used correctly!
jyl 11-30-2025 07:47 PM
What is a good brand?
look 171 11-30-2025 07:50 PM
Makita cordless is all we use. I think there's a reyobi floating around somewhere I saw somewhere
gregpark 11-30-2025 07:58 PM
Mine is Bosch but yes, the Japanese power tools are really good and cheaper
MBAtarga 11-30-2025 08:06 PM
I'm going to sit here with this thread open until Wednesday to see the planer put to use.
http://forums.pelicanparts.com/uploa...1764561992.jpg
LWJ 11-30-2025 08:08 PM
I am a fan of that sweet sweet stove!
Way back, my house had a stove that was 4 burner, brown, and the cabinets were cut for a larger (60?) inch stove. We had a nasty gap. I was making about 20K a year and my wife was a first year teacher. So, money was very tight. My Dad showed up with a junker stove from my Aunt's house. One, it was beautiful - like yours. Two, it actually fit my kitchen. We swapped out our brown POS for a sweet vintage stove and felt like we won the lottery.
So I get it! Congrats!
Zeke 11-30-2025 08:22 PM
I didn't read all the posts. if the cabinet is to be installed against the taller one just remove the left panel, cut your style and top and reinstall. AFA is not being symmetrical with the RS cabinet it is what it is (tell the wife). If the inside of the LS interior of the left cabinet means anything, throw a piece of thin veneer or paneling in there.
The proper way to do it is shave both left and right cabinets. Wife happy, you not so much with 2wice the work. Do remember that things expand with heat. Don't make it too tight or you will be sorry. Also that metal top will transfer heat. So will the sides. They are meant to be free standing and code says one inch of air space both sides plus the back.
You really are trying to put a 5 pound load in a 3 lb bag.
I'd build all new cabinets for each side with all the new cool features you might want there. Win, win.
wdfifteen 12-01-2025 05:45 AM
First, I would go with making it less wide rather than more narrow.;)
Assuming Im seeing the problem correctly, I would take that side panel clear off and install on the frame from the inside.
A930Rocket 12-01-2025 07:37 AM
If you’re going to buy a battery powered planer, I would get whatever brand tools you already have. I have a DeWalt planer, but it’s kind of heavy. Maybe they all are?
Planers can throw some wood chips, so tape your shop vac to the outlet to keep dust down.
javadog 12-01-2025 07:54 AM
Having read the thread again and taken note of the additional information, I might have a different opinion. Since you appear to have new cabinets on either side where I thought there were existing walls, I'd make two new small cabinets, as Milt suggested.
gregpark 12-01-2025 08:19 AM
I agree. Since the cabinet sides are flush to the opening and so small, I'd just make new boxes using the existing doors
masraum 12-01-2025 09:36 AM
I'd really rather not try to disassemble the glued and nailed cabinet which seems likely to end up breaking things in a way that would make it impossible to get back together cleanly.
Wife's gotta be happy. I can't tell her "live with it" if she's not happy with the results. Fortunately, she thinks she may be ok with the results of thinning the one cabinet.
And because of the way the knuckleheads put the kitchen together, it would involve me having to remove the 7' tall, 650# built-in refrigerator from the one cabinet to get to one (at least) screw that was run the other way between the cabinets. I'm REALLY hoping to avoid moving that fridge.
Interesting. I don't think I've ever seen a stove with a 1" gap on the sides.
Yes, I don't plan to make the fit super tight. And the top edge of the side panels has a ridge, so the rest of the side is farther away from the cabinet on either side (although not an inch). And the top won't be that close to the stone countertop (stands ~¾" proud and bottom edge ~¼" from the stone).
These are basic. No fancy features needed. The missus has plans to install premade pullout features in them.
I'm not confident that the cabinet can be dismantled without being destroyed past the point of reassembly.
masraum 12-01-2025 09:43 AM
I do like and have some battery powered stuff, but for this sort of thing, I went corded. Battery powered stuff is great, but sometimes I want the grunt and staying power of a cord.
That was the original plan. But it seems worth it to see if I can reuse the existing since it's mostly just some of my time. (the new tool is just a bonus).
The main reason that I'm wanting to go or at least try this route if possible is to 1) save some time and money, and 2) not have to remove the enormous refrigerator from the cabinet that it's in.
For the one cabinet that I have already removed, there were a couple of screws from inside the small cabinet into the side of the larger cabinet next to it, and then another couple of screws into the wall behind it. But for the small cabinet that I haven't removed, the knuckleheads that built and installed the cabinets put at least 1 (that I know of) screw from the large cabinet into the small cabinet. The only way to get that screw out is either to cut between the cabinets with a multitool or wheel the refrigerator (650#) out of the cabinet that it's in.
Whether I'm able to thin the existing cabinet, or I try and fail and have to build a new cabinet, it will be a learning experience.
A930Rocket 12-01-2025 12:42 PM
Since you only need to make the opening 1/4”+ or so wider, and give yourself a little more room, I would be inclined to disassemble one side of the cabinet, not install installed.
Instead of trying to break apart the current glued and nailed joint, I would use your Skil saw to cut the box down as needed on the top/bottom/backsides. Once the side is off, you can dress it up the inside of the side you removed,and reattach it.
For the face frame, with an oscillating saw you could detach it from the box, before you cut the box down.
When you reassemble it, the only place somebody might see anything, is the bottom joint on the inside. A bit of caulk will take care of that.
Just food for thought.
masraum 12-07-2025 04:20 PM
planner (for the cabinet) and angle grinder (for the stone top).
http://forums.pelicanparts.com/uploa...1765153135.JPG
It fits. I still need to caulk the front and top of the cabinet to cabinet and cabinet to wall interfaces.
I need to pull it back out and connect to the line and get a propane tank, and do a little maintenance on the oven.
gregpark 12-07-2025 04:34 PM
Nicely done, Bravo!
Cool stove
A930Rocket 12-07-2025 05:16 PM
Nice work!
When you say propane tank, are you talking about a big one, outside the house?
masraum 12-07-2025 06:04 PM
Originally Posted by A930Rocket (Post 12575093)
Nice work!
Yes, a big one outside the house. Apparently, you can get a 120# tank and mount it just outside the house. If you want the BIG tanks (250gal, 500gal, 1000gal) there are a bunch of codes about how far they have to be from the house, windows, sources of spark, etc.... We don't have anything in the house running on propane so I'm going to go with one of the 120# tanks.
