need to make a cabinet ⅛" more narrow - possible?
We got a stove, and it's ⅛-¼" too wide for the space. I am pretty sure that with ⅛" I could fit the stove in.
The face of the cabinet is poplar. The side is ¾" cabinet ply. The top is quartzite (natural stone). The stone is set about 5/64" shy of the surface of the ply on the side of the cabinet that I'd be removing wood from (side up against the surface of the other cabinet). And on the other side, the stone is about 1/32 proud of the surface of the plywood/side of the cabinet. The stone top seems to be "glued" to the top of the cabinet. Removing the stone to trim down and put onto a new cabinet will likely involve lots of time spent with an oscillating multitool which sounds like a PITA. I hate to rebuild a cabinet if I could "shave" the existing cabinet down enough to make it work. If I give it a shot and can't make it work, then all that I've done is wasted some of my time since the cabinet won't work as it sits anyway. Saves me having to buy a bunch of plywood and poplar and build a cabinet if it does work. http://forums.pelicanparts.com/uploa...1764543618.JPG What do you guys think? |
It can be done. Pain in the ass...
Make sure it really will work with an 1/8th off. Measure top, bottom, middle, front, back. Could also inset it into the wall. Might be better to trim a little off both sides so you don't notice. Of course, you need to also consider what style of door you're going to use. |
Cabinet is already out? Cut the scribe 1/8?
But MORE of a PITA than buying a bunch of expensive wood, building a new a cabinet, and having to get the countertop stone off of the old cabinet and ready to apply to the new cabinet? I'm not sure. Quote:
I had originally planned to remove both and rebuild both. The first one that I tried to remove is the one that's still in place in the photo. I removed all of the visible screws and cut the caulk with a razor (same process as the one that's been removed in the photo). But, it turns out that the installed, must have put at least one screw through from the other cabinet into that one. To remove that cabinet, I'll have to use a multitool to cut that screw that's coming through from the wrong direction, and hope that it's the only one. The other alternative would be to remove the built in dacor refrigerator that's 7' tall and 650# IIRC from the cabinet to remove the one screw that I know about and any others. I REALLY don't want to pull out that fridge! That's why we're even considering having a slightly asymmetric fitting. |
http://forums.pelicanparts.com/uploa...1764550267.JPG http://forums.pelicanparts.com/uploa...1764550267.JPG |
It wouldn't be nice, you have a power plane? Shave off the entire side 1/8 and shove it back in there. 10 min job
Yeah or even a belt sander with heavy grit. But usually those sides arent very thick 1/4" or 3/8" not that it matters much
You may have to plane, check the oven, repeat as needed. And if you want it to look pretty, you can stand it afterwards. |
I have confirmed that the plywood side of the cabinet that I need to thin is 17.5mm, so 11/16". I'd forgotten about my belt sander and was thinking about how much time it was going to take with my little cordless ¼ sheet palm sander. Duh, corded monster belt sander FTW! |
Go to Lowe’s, Harbor Freight, and get a cheap power planner. Don’t forget to set your nails. Even with the most aggressive sandpaper, you’re going be there for a while.
No sander. You will end up with valleys and hills and you will want to throw both sander and yourself out the window after a couple hours covered in dust.
Someone made those cabinets, not bought from a bog box store. Lets split hair for a second. That side looks to be an imported plywood so its more then likely a little thinner then 3/4". You need 11/16, so that's only 1/16 you need to shave down. Technically that will work, but somehow, the gods ain't with people like us on such horrible product, plywood, so you are correct, 1/8 is what you need ( doesn't matter thickness of plywood at this point). I know you have a router, but if you really want to abuse yourself, make a carriage along with a 3/4" straight cutting bit and set the router to cut 1/8 off after 1000 passes to achieve the 1/8" off the side of the cabinet. Its actually more accurate then the power plane. Me, I buy the plane and have everything in place, be done before dinner. |
You could set your skilsaw to a 1/8” cut (or 3/16”) and make a bunch of parallel cuts 1/4” apart, then remove the ridges with a chisel. This way you would remove exactly the depth of your cut. Once you go to town with a belt sander, you have no idea where you are at. You can then finish it with the belt sander if you want.
I do have an old router, but don't want to go that route (no pun intended). I'd rather take my chances with the belt sander than use the router. One the cabinet is thinner, the side that I alter will never be seen again because it'll be screwed up against the cabinet next to it. I'll look into the planer. Wouldn't the planer be more likely to chew up the cheap ply? |
I've got some 80 grit belts for my dad's old belt sander that could take that down so fast it'd make your head spin.
You are taking it off the side that goes up against the wall to the left, not the stove side, correct? There's room for error there is so. |
I've done it. Marked my lines with a sharpie and used a power planer for the face frame of the cabinet and my 4½" angle grinder for the granite. The granite went slower than the wood but nothing was too painful
No. You will be amaze at how well it remove the materials. We use the plane and belt sander to scribe many projects.
The task here is to remove a calculated amount each and every pass, roughness aside. Accurate amount is a very loose term here as long as you can take a different cut and not over the same planed path then it should accurate enough. Most plane will remover up to 1/16 materials at each pass. It can be set to 1/32 to not stress the tool or blades. Buy an extra set of blades if available and you will use the plane on other projects. It should do the entire side without issues. Personally, I would remove 3/16 near the back for less fighting with stove and everything else back there. Cheap ply or imported plywood? Look at the top layer of veneer from the edge. It looks to be some type of Birch or Maple from Asia, more then likely made in Viet Nam or Indonesia. The last ply or veneer is literally paper thin and it often comes off by peeling with one's finger nail. Its inexpensive compared to a domestic (shop) Maple, at half the cost. We don't use it. Call back on a 30k kitchen cabinet job would be a nightmare due to de-lamination of a piece of plywood. No thanks. |
There's plenty of room or material to be removed so don't be afraid to plow the plane through it. Its 3/4 (sorta)
What you must watch for is nails if the cabinet is made with dados for the shelf or rabbited for the bottom. Often a nail is shot to keep everything in place upon glue cure. |
| All times are GMT -8. The time now is 04:19 PM. |
