How can I fix this?
At some point, the plywood floorboard on the driver side of my 911 got wet or brake fluid dripped on it, and it’s damaged at the bottom left corner.
Looking online, I see new floor boards for $400 for Porsche and less for ABS or aluminum, which I don’t want. Design911 in the UK has one for $145, including tax and shipping, plus any shipping taxes/tariffs/etc. So, how can I fix what I have? I was thinking I could squeeze glue into the loose plywood sheets, clamp it up, to firm it up. Then splice in a small section, but the finished plywood I can source is 1/4” ($17) which I could sand down. And then, sandwich it with a veneer ($20). Total $37 and time. Tools are not a problem. Yes, I could buy something, but I like doing this kind of work. Ideas? ![]() ![]() ![]()
What about fiberglass cloth and resin. A few layers and let it dry?
Rutager West 1977 911S Targa Chocolate Brown |
Edministrator
Dude. $145...
Good post? Leave a tip! O - $1 O - $2 O - $3 |
As a builder, I work with wood all day, so that’s my go to method Hahaha! Last edited by A930Rocket; Yesterday at 05:51 PM.. |
Fiberglass is pretty easy, you cut the cloth to size or a bit over, mix the resin and hardener and brush it on. You can sand and grind as needed.
Leadfoot Geezer
Yes, and make a new metal hold-down bracket that fastens further up into solid wood.
Or, you could just cut the damaged section off and fashion a replacement in the same shape. Make a new larger hold-down plate that also serves to join the replacement piece to the undamaged section. ↓ Not quite what you're dealing with, but a similar concept...
'67 912, '70 911T, '81 911SC, '89 3.2 Targa - all sold before prices went crazy '13 BMW 335i coupe - current DD '67 VW Karmann Ghia convt. & '63 VW Beetle ragtop - ongoing projects |
Control Group
You guys are as bad as me
+1 for the fiberglass
She was the kindest person I ever met |
Minwax makes a resin that soaks in and hardens, then you could FG over it.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Good ideas, guys. I may tinker with it over the next couple of days and then decide if I want to buy the Design911 part. There’s no rush.
You do not have permissi
The beatings...i mean rust..will continue until morale improves.
It looks like metal+wood. Non-structural. Covered by carpet. How much time do you want to spend.
Meanwhile other things are still happening. |
I'd make a new, larger mounting bracket. Use the existing rivet hole on the right and make two new holes higher up in good wood to mount it. I wouldn't even fix the wood unless this is some over the top restoration project.
Epoxy can make space ships.
Trust me. You can glue up virtually anything with two part epoxy. |
Router bit with ball bearing guide on bendable plywood. Steam bend it. Make a bunch and sell them for 75.
Other than that, a small epoxy kit from HD will do you just fine. Clamp up with cauls covered with packing tape. Both surfaces will be perfect. Trim the edge and Bob's your uncle. |
GoFundMe .... I'll donate a little .... very little
![]() Only $144 left .... help him out boyz! |
Kantry Member
Or you could do what I did: Cut back to the area with no delamination, you should still be in the area where it is flat. Scarf join the piece to replace what was cut out.(You get to use epoxy for this). Cut the new piece to shape (you remembered to make a pattern, didn't you). Sand, paint, clean up the metal piece and reattach.
I just realized that was 25 years ago.
Best Les My train of thought has been replaced by a bumper car. |
