Send a message via AIM to fintstone
That is all supposition. Although Ritter may have some knowledge, he has made it clear where his sympathy lies. Ritter is just trying to spin this so he doesn't look so bad...as if that were possible. There is nothing to indicate this round was of the "base-bleed" type. He sure as heck has not been allowed to examine it. If it had indeed been fired already, it would not have exploded before they could disarm it. We alreay know this one was not inert.
What is the probability that 1. The folks doing R&D didn't recover duds that were chemical rounds to determine why they failed. 2. That a terrorist just happened to dig this one up out of the ground in the middle of the desert when stockpiles of munitions are almost everywhere. if you suppose the testing folks could not find it with spotters and metal detectors..why would yopu suppose a wandering terrorist..probably coming from a wedding party would be able to?
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 05-24-2004, 02:31 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #221 (permalink)
Originally posted by lendaddy
Man, some of those guys really know their stuff. But 350 says it'll only hold 2 liters? Who's right? I really wonder, no really
Yep..either do it the hard way..volume of a cylinder= pi times the radius squared times the height
or the easy way..visualize two, 2-liter cola bottles stacked on top of each other. ..voila 4 liters in a standard shell
Old 05-24-2004, 02:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #222 (permalink)
Senior Member
Superman's Avatar
I've got a couple of questions. Did this Weapon of Mass Destruction explode? If so, how many hundreds of thousands of people died?
Mocha 1978 911SC. "Coco"
Old 05-24-2004, 02:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #223 (permalink)
CamB's Avatar
uh.. . Cam, (pi)×(dia) gives you circumference. . . .not area.
DAmmmmmmiiiiiiiiiittttttttttttttttttt!!!!!!!!! Maths > me. (edit) really, I can't believe I cocked that up. So, so, so embarrassed
Wait a minute - you're being dishonest with your maths - for instance using 10cm diameter (not your 15cm) inside gives a 50cm long "shell" (inner diameter again).
Taking account of the cone shape at the end and it would be longer still. Plus the explosive bit inside to bust the mother open on impact.
Having said that, I'm quite happy to concede that 4 litres is possible. Like I said before, I've never seen a 155mm shell before
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #224 (permalink)
Once again, luckily it was not poperly used and the soldiers neaby had the antidote on hand....The weapon's design is that it has to be launched as a projectile to mix the chemicals properly via rotation.
The point is not so much that the terrorists used a chemical weapon..but that it proves Saddam did not destroy this one.
Old 05-24-2004, 02:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #225 (permalink)
techweenie's Avatar
Fintstone: "We alreay know this one was not inert."
I don't know that. Where do you get your information?
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 05-24-2004, 03:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #226 (permalink)
Of course once could inflict greate casualties with say, a bad batch of chili; Saddam's got nothing on my culinary (non)-experise.
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #227 (permalink)
350HP930's Avatar
While the exterior volume of a 155 millimeter shell exceeds two liters one needs to keep in mind that the shell is rather thick and there needs to be volume reserved for the detonator and bursting charge.
If memory serves me correctly a conventional shell has walls that are about an inch thick leaving an explosive volume of approximately one to two liters of high explosive. I imagine the walls are thinner in a CW shell but it has to reserve some room inside for the non chemical parts.
I am sure whoever is throwing out these quantities is basing their math on flawed assumptions like a shell is built like a coke can.
Old 05-24-2004, 03:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #228 (permalink)
Dept store Quartermaster
lendaddy's Avatar
There are many forms of 155mm shells, what did you base your 2 liter assumption on?
Cornpoppin' Pony Soldier
Old 05-24-2004, 03:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #229 (permalink)
350HP930's Avatar
A shell with one inch thick walls that is about a half a meter long. Don't forget to calculate for the taper.
Old 05-24-2004, 03:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #230 (permalink)
lendaddy's Avatar
Why does it have to be only 1/2 meter long, that's my question.
Old 05-24-2004, 04:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #231 (permalink)
Information Junky
island911's Avatar
Originally posted by 350HP930
A shell with one inch thick walls . ..
why would a shell, designed to carry toxic stuff, have 1" thick walls?
The idea is to disperse the load, not pyrolyze it.
Old 05-24-2004, 05:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #232 (permalink)
CamB's Avatar
Seriously though, how thick does it have to be? They do get shot out of a cannon after all, and it wouldn't do for them to burst at the "friendly" end.
1975 911S (in bits)
Old 05-24-2004, 07:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #233 (permalink)
araine901's Avatar
hundreds of thoudsands did not die becuase of its delivery. As I understand it the Two chemicals need to mix in motion to become active. The fact that the two treated were not treated for blast injuries only exposure leads me to belive they detonated it to destroy it not knowing its contents. I guess they are not marked very well. I belive based on the stats from when Saddam used these in Iran they only kill 5-6K each. But they can launch 5 or 6 a minute.
'66 911 (sold to Magnus Walker)
'63 Myers Manx
'67 Cal Bug
'02 GTI 1.8T
Old 05-25-2004, 05:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #234 (permalink)
