Thread Killer
Teutonics's Avatar
resources/forums for small engine/mower repair?
Anyone know of on-line resources for small engine repair? I just got a riding mower that I would like to rebuild the engine, but can't seem to find any resources for torque specifications, tolerances, etc. I found exploded view parts diagrams on the B&S site (very cool BTW), but no service information.
Specifically I'm looking for detailed information on Briggs & Stratton engine model number 28n707 type 0121 (15HP I/C OHV).
Any leads would be appreciated!
Allen
'85 911 Coupe
'75 BMW 2002
'02 Ducati Monster 900ie
'18 GMC Sierra Denali 6.2L 4wd
Old 08-06-2004, 11:50 AM
vash's Avatar
me too! i search and found a useless bbs on small engines.
i need help with a suitcased sized honda generator (EM500). the carb needs rebuilding.
poof! gone
Old 08-06-2004, 11:52 AM
I used to rebuild these things when I was a kid. Just take it apart and replace the "consumables". Simply reverse the operation to reassemble.
Actually, there are a couple of worthwhile books on the subject which include specs on tolerances and adjustments. They may also be in the library.
Cliff is that a 2 stroke engine with a diaphram carb?
Warren & Ron, may you rest in Peace.
Old 08-06-2004, 12:32 PM
BTW, one of these CDs from Ebay may be very helpful.... http://search.ebay.com/small-engine-repair_W0QQsokeywordredirectZ1QQfromZR8
Old 08-06-2004, 12:53 PM
vash's Avatar
no, it is a 4 stroke. i got the carb all apart and i cleaned the crap outta everything, but no go. it runs sweet if i play the part of the carb with a can of starter fluid. i am thinking vacumn leak.
poof! gone
Old 08-06-2004, 01:31 PM
Might be time for a rebuild kit.
Old 08-06-2004, 02:25 PM
vash's Avatar
rick i am thinking the same thing. the fuel was varnish. at least it doesnt look hard.
poof! gone
Old 08-06-2004, 02:43 PM
Be careful of the "soak in Easy-off" tricks. They remove varnish AND plating. Not good.
Old 08-06-2004, 03:09 PM
The cost of having a carb rebuilt by a B+S shop is too cheap to try to do yourself. I just had my 18hp card rebuilt for $17. The pickup and return of the mower cost $18. The parts kit would have cost me $10 and a lost weekend screwing with it.
However, if you are going to try a carb, or engine, rebuild, B+S has a good book at there website. I don't remember the the title but it was easy to pick out. About $30 on my doorstep. I bought it since I have 10 B+S motors to keep running for my mini-farm (20 acres) in PA.
Terry
Terry Hastings
Baltimore, MD
1972 911T
LTHSURVEY@AOL.com
Old 08-17-2004, 05:36 AM
Occam's Razor
cmccuist's Avatar
This is the best "free" information I have found for troubleshooting small engines and reparing lawn mowers.
Small engine repairs
This is a text file that you can copy and make a Word document out of it and then search for your specific problem.
Craig
'82 930, '16 Ram, '17 F150
Old 08-17-2004, 11:58 AM
If you had a varnished (old gas) carb that you have taken apart - cleaned - put back together and it still doesn't run right, then you did not get it clean enough. Those little carbs have very small holes and one is probably clogged. Take it apart again - clean with xylol - use a strand of very fine wire to poke all the holes and blow everything out with compressed air. Should solve the problem. I clean 2 stroke carbs all the time due to inactivity and old gas. If you clean every hole - some are hard to find - then it should work with no new parts required (except gaskets if they get damaged.
Randy
'87 911 Targa
'17 Macan GTS
Old 08-17-2004, 02:26 PM
vash's Avatar
randy, i forgot about this thread. thanks. i put the generator in the corner and i blew it off. i will re-visit it this weekend. looks like my girlfriend's little suzuki will need to be address before it is in the same hell.
poof! gone
Old 08-17-2004, 05:21 PM
Retired in Georgia
Robert Coats's Avatar
You can get the shop manual for the EM500 here:
http://www.helminc.com/helm/product2.asp?class%5F2=AHP&mk=Honda+Power+Equipment&yr=All+Years&md=Generators&dt=Shop%2FService+Information&module=&from=result&Style=&Sku=6189202&itemtype=N&mscsid=52EC8EURD3LX8GU6SLMFH5H138HW8QF4
Disclosure: I work for Honda Power Equipment, and in a VERY small way, purchasing this document will benefit me.
I've got five kids, an Italian wife, and I (used to) write about lawn mowers. You think you have problems?
-Robert Coats
Old 08-17-2004, 05:52 PM
