Baseboard trim installation question
I just finished a refresh on a powder room and installed the wooden base board. While it looks nice there is a slight bow in the wall and I see a gap were I can't nail since there's no stud behind the area?
What are the tricks to making a closer-to-the-wall fit? Shoot glue behind the base board and place a heavy object against it till dry?
BTW, I kept the finish natural (Poly-acrylic clear satin) and shot 16 ga finish nails to secure. Also, the baseboard is over textured paper wallpaper.
Warren & Ron, may you rest in Peace.
Old 08-16-2004, 09:07 AM
ttweed's Avatar
There should be a bottom plate in the wall framing which provides backing for the baseboard fasteners at every point along the wall, and prevents any "bow" at the bottom. Something is goofy with your framing if you have nowhere to nail between studs.
TT --(retired carpenter)
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 08-16-2004, 09:22 AM
So I'd nail at an angle down ito the base plate?
Old 08-16-2004, 09:37 AM
Seldom Seen Member
Burnin' oil's Avatar
The best you can do is shoot into the bottom plate and pull the baseboard in as tight as possible. A gap along the top of the baseboard and between the stud is tough to fix. You could try shimming at the very bottom of the baseboard and shooting into the bottom plate above the shim, which might bring the top in. Good luck
Why do things that happen to white trash always happen to me?
Got nachos?
Old 08-16-2004, 09:51 AM
Detached Member
Hugh R's Avatar
Finish carpenters use white bathroom caulk to fill the gap. You should always caulk the seam on the top of the baseboard, it looks more finished.
Hugh
Old 08-16-2004, 10:19 AM
Hugh,
The problem is there is only one spot with a small gap. Additionally, if I fill with caulk it'll look like crap between natural wood and the wall paper.
Ttweed 'n Burnin: Is this what you recommend? I hope the 2 1/2" nails will be long enough.
Old 08-16-2004, 10:30 AM
Seldom Seen Member
Place the shim (something small) behind the baseboard. The shim is the pivot point and when you nail above the shim and into the baseboard, it will pull the top in - somewhat.
Got nachos?
Old 08-16-2004, 10:54 AM
Ok...kind of the see-saw effect?
Old 08-16-2004, 10:59 AM
Seldom Seen Member
'zactly
Got nachos?
Old 08-16-2004, 11:03 AM
Thanks guys!
Old 08-16-2004, 11:04 AM
TSNAPCRACKLEPOP's Avatar
doesn't anyone use duct tape anymore?
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 08-16-2004, 11:05 AM
ttweed's Avatar
Didn't you get the memo? Duct tape was the 90s. This is the decade of the zip-tie.
TT
Tom Tweed
R Gruppe #232
Old 08-16-2004, 04:54 PM
i just clicked on your link to solo car, the number is blue duct taped, no zip ties, time for another update!! lol
Old 08-16-2004, 04:58 PM
but that fuel system is chock full o' zip ties!!!!
Old 08-16-2004, 05:03 PM
if the trafic is not too high. you also might be able to get away with putting a nial in from the top of the moulding at a 10 degree angle (say from 1 oclock to 7 oclock) while holding the baseboard against the drywall. the idea being that the nail catches the drywall at a sharp enough angle to hold the baseboard in. Youll probably need more than one nail. Iv e done it in a pinch in the past.
ps. push on the baseboard with a piece of wood not your hand. Ive seen nails do 90 degree turns when shot at crazy angles.
76/3.0 tarcabvertible
64 corvette conv.
72 Alfa GTV
79 Jeep Cherokee Chief
Old 08-16-2004, 06:17 PM
can you put some type of fastener behind the wallboard, and pull it out a bit with the fastener scrrew,,,,,,like those spring loaded nuts, or a plastic sleeve thingy? how aboout sliding a coat hanger behind it underneath, close to the floor, pulling the wallboard out while glueing and inserting fastener?
how about a nice trim piece over the gap?
Old 08-16-2004, 06:54 PM
clear caulk might take care of it or perhaps a strategicly placed plant/laundry basket/magazine rack.
64 corvette conv.
72 Alfa GTV
Old 08-16-2004, 07:10 PM
