vash's Avatar
can i tow a jeep CJ-7 with a tow bar, all four wheels on the ground?
never done it, but my scrambler needs to be taken somewhere, can i put the transfer case and tranny in neutral and tow it safely? i seem to remember a lubrication issue.
cliff
poof! gone
Old 11-01-2004, 11:30 AM
Recently Disbanded
juanbenae's Avatar
i see jeeps towed behind trucks and motorhomes all the time.
Old 11-01-2004, 12:26 PM
Short distance should be fine.
Old 11-01-2004, 12:28 PM
Parrothead member
VINMAN's Avatar
No problem at all. I flat towed my CJ-5 all over the place
Vinny
Old 11-01-2004, 12:35 PM
rcm rcm is offline
rcm's Avatar
Trans in neutral and transfer case the same.
Rick
" too many people spend money they haven't earned to buy things they don't want to impress people they don't like" Will Smith
Old 11-01-2004, 03:29 PM
Non Compos Mentis
Just don't try to tow it with a CJ-5.
Old 11-01-2004, 07:35 PM
Stanley's Avatar
I woudn't do it unless the drive shafts were disconnected to be safe. I don't know about jeeps, but I know that toyota 4x4's should not be flat towed unless the drive shafts are out.
'78 SC
Old 11-01-2004, 11:08 PM
Hey Cliff, I agree with Stanley. The driveshafts should be disconnected to be safe. There SHOULD not be any problems in neutral, but I have heard of situations where the transfer case or the tranny slip into gear etc. - bad thing.
I guess it depends on how long of a distance......
Didn't even know you had a 4x4, what is the story on it? Rock crawler? Run about?
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 11-02-2004, 09:20 AM
I am not sure about the older transfer cases but the AX15's in the Wrangler's don't have true neutral. The choices are tow it flat or on a trailer/flat bed, never with one set of wheels in the air. If you have bolt on yokes and not a slip yoke, then I agree with the suggestion to remove the driveshafts to be safe.
Old 11-02-2004, 09:39 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Ideally, you want to disconnect the driveshafts. Put both the transfer case and tranny in neutral, and unlock the front hubs if you can.
BTW, changing a transfer case on a 76 GMC is a PITA!!!!!!!!
My old mud whomper.....
Old 11-02-2004, 09:53 AM
Just thinking out loud
mattdavis11's Avatar
I don't know who told you that Stanley, but it's false. I towed a 1990 automatic transmission L/C by chain, with a 16 foot flat bottom boat and trailer behind it, with my Ram Charger for 150 miles. Transfer and trans in nuetral. No ill effects to any vehicle, that was 8 years ago, and the L/C is fine still. Now that was not the smartest thing I've ever done, I admit, it worked though.
91 FJ80
84 Ram Charger (now gone)
Old 11-02-2004, 12:16 PM
Stanley's Avatar
Yes you are correct, it CAN be done. But theres a very large risk you are taking as the gears can engage. Its just not worth the risk of ruining your entire drive train. If you want some proof search on pirate4x4.com.
I'm also trying to figure out how you can tow a Toyota truck by a chain and then have a 16 foot trailer behind the toyota- something doesn't add up.
'78 SC
Old 11-02-2004, 11:07 PM
This is how. I drive the lead vehicle, the chain connects to the rear of my vehicle and also to the front end of the Land Cruiser. The trailer and boat are attached to the L/C via a ball and the trailers hitch. The operator of the L/C steers that vehicle, and also does most of the braking for the lead vehicle (me). The caravan was much longer than any 18 wheeled semi that you normally see on the freeway. It was not a very smart thing to do, but it was legal, at least then.
91 FJ80
Old 11-04-2004, 09:45 AM
Eric 951's Avatar
Jared,
Although a Ford Truck man myself--nice truck!
I always like the GM short-box flaresides.
Eric
83 911SC/83 944
bunch of Honda 750s
Old 11-04-2004, 10:00 AM
