Me like track days
Craig 930 RS's Avatar
Question VW 1.8 T questions - what 'WORKS' for HP??
Spousal unit has a 2003 VW Beetle Turbo - had the ECU reflashed to bring HP from 150HP to 209HP & 242TQ.
What else is there that is PROVEN to be worthwhile to increase HP & TQ? Trying to stay far away from gimmciky hoses and overhyped 'down pipes' (if in fact this is true) etc.
European Car mag apparently has had has a ton of articles on this engine, but since I suscribed they have not had much.
What works - that isn't BIG bucks?
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 01-02-2005, 05:15 PM
Free minder
Aurel's Avatar
Nitro?
Aurel
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 01-02-2005, 05:38 PM
Senior Member
contact Rene Berube of Upsolute and he can give you all the advice you could ever want
rberube@upsolute.com
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 01-02-2005, 06:08 PM
Me like track days
E-mailed Rene - THX!
Craig
Old 01-02-2005, 06:39 PM
chuckw951's Avatar
Check on www.vwvortex.com. I believe a larger turbo is available for the 1.8T.
1981 Porsche 931 w/S1 engine & g31 transmission. Water-cooled intercooler
Old 01-03-2005, 02:55 AM
Z-man's Avatar
Craig911:
Funny, my better half also drives a 2003 New Bettle Turbo.
Can you provide details with how the ECU was reflashed?
BTW: A new beetle message board is HERE.
Thanks,
-Z.
2010 Cayman S - 12-2020 -
2014 MINI Cooper S Coupe - 05-17 - 05-21
1989 944S2 - 06-01 - 01-14
Carpe Viam.
Old 01-03-2005, 06:25 AM
Me like track days
https://secure7.nexternal.com/shared/StoreFront/products.asp?CS=achtuning1&CategoryID=88&Refresh=True
Under APR performance chip upgrade
Made a HUGE, HUGE, difference. An absolute rocket!
Plus, you can select vis cruis control the stock or performance program.
Old 01-03-2005, 06:55 AM
Me like track days
Or even better:
http://www.goapr.com/VW/products/ecu_upgrade_beetle18t.html
Old 01-03-2005, 08:10 AM
Still Doin Time
asphaltgambler's Avatar
Free up the exhaust side, then it's onto a larger turbo and possibly matching header and larger intercooler, back to the intake side with larger t-body and runners, next are cams, so on and so on.
The basic long block will safely handle 350HP on pump gas.
Old 01-03-2005, 10:02 AM
Did you get the memo?
onewhippedpuppy's Avatar
I've always heard that 220 - 250 HP is the limit on the stock KO3 turbo, 300HP is pretty easy with a KO4, but then you're getting pretty pricey and serious. asphaltgambler pretty much covered it, I know on an A4 you can convert the crank driven fan to a second electric unit to free up a few HP, and put it on a thermostat to run after the car has shut off to help cool the turbo. Run synthetic, your turbo's bearings will thank you, and if you haven't yet, upgrade your diverter valve to a 710N off of the 220HP 1.8T TT, or better yet an aftermarket unit.
‘07 Mazda RX8-8
Old 01-03-2005, 06:09 PM
Me like track days
Hey thanks for the advice, guys.
Matt - What does the diverter valve change bring?
Old 01-03-2005, 07:17 PM
i want one of those...
Rufblackbird's Avatar
Location: formerly a grass shack in Hawaii, now Peoria, AZ
If I'm not mistaken (though I very well might be) the Audi TT has the same 1.8T motor as the rest of the VAG family, but it's only the software that gives it its 225hp (the 225hp version, anyway). With decent software (APR is good, but I'm a fan of GIAC), K04 (or bigger) turbo, bigger (front mount) intercooler, plus an intake and exhaust (downpipe + cat back) will net you close to 300hp.
a couple sites to visit:
www.eiptuning.com
www.abdracing.com
www.neuspeed.com
www.techtonicstuning.com
http://www.bahnbrenner.com/
www.eurosportacc.com
www.momentummotorparts.com
Jeff
'72 911 T Targa widebody VTK #111385 http://www.911vtk.com
Old 01-04-2005, 03:11 AM
Still Doin Time
Yes the Audi 1.8 is the same except for software changes
Old 01-04-2005, 05:22 AM
The TT does have a few other small changes, can't remember what though. The ECU changes basically crank up the boost, so the TT has an updated diverter valve. The diverter valve basically opens to bleed off excess boost when the throttle is closed to prevent turbo damage, but the stock one on the 150HP 1.8T is notorious for not holding like it should, especially when you chip and raise the boost. The 710N is the upgrade for the 220HP TT, or even better are the multiple aftermarket ones, I'm sure APR carries one. If you have a chip do it, you might be losing boost and Hp.
‘07 Mazda RX8-8
Old 01-04-2005, 03:34 PM
http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?make=Volkswagen&engine=1.8T&model=New%20Beetle&submodel=&category=Engine&subcategory=Turbo
http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?make=Volkswagen&engine=1.8T&model=New%20Beetle&submodel=&category=Engine&subcategory=Intake
One of these is a frequency valve that is supposed to give 10HP, the other is the page with diverter valves.
‘07 Mazda RX8-8
Old 01-04-2005, 03:50 PM
ValveFloat's Avatar
The Beetle has an electric fan since the motor is transvers, and all VWs will run the fan with the car off if the water temp is high enough.
Joe
1993 C2
Old 01-05-2005, 08:39 AM
Turbos are usually oil cooled (some are both oil/water), and it's actually a turbo timer that will help it cool down.
Jeff
Old 01-05-2005, 01:07 PM
[QUOTE]Originally posted by ValveFloat
The Beetle has an electric fan since the motor is transvers, and all VWs will run the fan with the car off if the water temp is high enough. [/QUOT
Nice, my A4 is longitudialy mounted, it has a crank driven fan, with an electric to supplement it. Ruf, a turbo timer is a better option, but there is a tech article on Audi World about converting the crank driven fan to an electric, and putting it on a thermostat to run after the engine is shut off to help cool the engine and turbo to prevent oil coking. At the least, it can't hurt. Eliminating the crank driven fan frees up a few HP too.
‘07 Mazda RX8-8
Old 01-05-2005, 04:48 PM
