B58/732
More bobber bits
Getting the rear axle spaced w/ the brakes was a major PITA.
And, I just spent HOURS grinding ***** off the frame and you can't even see it in the pic...
ΜΟΛΩΝ ΛΑΒΕ I don't always talk to vegetarians--but when I do, it's with a mouthful of bacon. |
Senior Member
Aaron,
Hope you are not grinding inside! Wife would de-nut you with the carpet and such. Are you using an air or electrical grinder?? Should not take that long with the right tools... Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
B58/732
Joe,
Of course not...it's in the garage, and the carpet is scrap junk that's been reserved for this purpose (mostly keeping my knees intact). I'm using a Makita 10k rpm electric grinder...no air tools in my collection (nor tank). The issue is that there are so many damn tabs on the frame that I ended up not using. And it's thick stuff with huge weld beads. And I have to be careful not to heat it up too much or whack into the tubing...just a PITA.
