Dept store Quartermaster
Can I add RAM to my laptop?
There you go, how do I "pimp my ride" so to speak?
It's a Toshiba Satellite and I really like it. I have 512k now, but I don't know what type or where to look etc...
Cornpoppin' Pony Soldier |
Information Junky
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Thanks Island,
That's a great site!
drag racing the short bus
I've read in several computer magazines and also online that anything over 512 megs of ram is a waste unless you're using very ram intensive programs. A faster hard drive might be another way to go.
The Terror of Tiny Town |
However, DD74 makes an excellent point. The HD is currently the week link on my PC. I would recommend getting the fastest HD you can find! |
More ram is always good for a laptop, since more ram == less disk swapping == more power effecient. Personally I have 512mb in my dual cpu desktop system and only use swap space when I play games and do something else cpu intensive like compiling a large program at the same time...
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
RAM is the cheapest speed enhancer there is, otherwise you need to look at bus speeds, processor speeds and that means a new computer.
steve old rocket inguneer |
512MB is a lot of memory for most uses. Unless you are working with very large graphics file, etc, you might not need more memory.
Go to Task Manager and see how much memory you are using, use Performance Monitor to see how much you are hitting the page file, and listen to see how often the hard drive is accessing. If you aren't swapping to the hard drive much, then more memory will be of little benefit.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
The Unsettler
The hard drive in laptops are generally 4200 or at best 5400 rpm, it's a HUGE bottleneck especially for a us creative types with large scratch files.
I replaced my 80 gb 5400rpm with a 60 gb 7200 and the box flies. Currently your only choice is from Hitachi and 60 gb is as big as they go. Mine has been in almost a year and has been rock solid, surprisingly it's also on the quiet side. Take your old drive and put it in an external portable enclosure.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Senior Member
One thing to do first is to open the RAM cover and see whats installed currently. If its 2 256 sticks then you need to buy differently than if there is one 512 stick installed AND an open slot available.
Agree about the hard drive and disagree with the RAM concerns. I have 1 gig on my laptop and 1.5 gig on my desktop. More memory almost always helps and more room and a faster hard drive always helps. Just went from 30 to 60 gig on my Dell laptop and it flies... JoeA
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
