Detached Member
Hugh R's Avatar
1972 VW Bug Tune up Specs.
Hey All
Going to help my daughters boyfriend "fix" his 72 bug tomorrow night. He got in to tune it up and screwed it up. Don't know much about bugs, anyone know the following:
firing order
Plug Gap
Point Gap
Ignition timing low and high speed if applicable?
Anything else?
Thanks much
Hugh
Old 04-24-2005, 06:57 PM
id10t's Avatar
Get John Muir's book "idiots guide to keeping a vw alive forever" - it will be all he needs. Heck, I use it as a what-to and how-to on my 356, and use Elfrinks et al. for specs.
Anyway, firing order is 4123 clockwise, static timing should probably be 5 degrees before TDC, full advance at 3000 rpms should probably be 30 deg. Plugs i'm not sure on, the 356 uses 024 but I thnk it may be more plug dependant, points should be 016, dwell should be 50 deg. Valves should be 006 on both intake and exhaust, although some prefer 008 if drivin in hot weather, etc.
Old 04-24-2005, 07:23 PM
Detached Member
Hugh R's Avatar
Hey id10t
thanks very much.
Hugh
Old 04-24-2005, 08:38 PM
I don't have my book with me but I believe the firing order is 1432 and the engine I did recently the timing was 10 degrees BTDC. I got my specs from a Hayne's manual. I'm pretty sure that's what it is- with due respect to the previous post, I don't think that's right- but I could be wrong.
Old 04-24-2005, 08:47 PM
Team California
speeder's Avatar
This info is wrong. Firing order is 1-4-3-2, what you wrote would be 1-2-3-4!
Make the kid run down to Pep Boys and buy a Haynes manual for it, (should be in stock), it will come in handy for him and you'll need it right now for reference.
Denis
Old 04-24-2005, 11:33 PM
id10t's Avatar
Right on the firing order (what i posed is backwards), shows what I get for posting after a couple of Newcastles... Good thing I don't work on my car in that condition, huh?
Muir's book is still the one to have.
Old 04-25-2005, 06:35 AM
Double Trouble
targa911S's Avatar
with the "revised" firing order that all looks right. You can static time it with a cheapo lite pretty easily too.
I used to be addicted to the hokey pokey..........but I turned myself around..
75 914 1.8
2010 Cayenne base
Old 04-25-2005, 06:37 AM
id10t's Avatar
I do my static timing with a tail light bulb in a holder with a few aligator clips on the ends on the wire. One goes to the coil where the wire to the dist. condensor attaches, other end to ground. With the key on, when the points open the light lights.
Old 04-25-2005, 08:06 AM
Detached Member
Hugh R's Avatar
Thanks guys, I'll have him buy a Haynes and the Muir book.
I knew I could count on you all for good reliable guidance.
Hugh
Old 04-25-2005, 08:36 AM
The Zundfolge is stamped right on the generator stand!
Old 04-25-2005, 08:58 AM
Detached Member
Hugh R's Avatar
The what?
BTW, I assume the cylinders are numbered like the Porsche i.e., LF=1, LR=2,RF=3. RR=4?
Hugh
Old 04-25-2005, 09:08 AM
Zundfolge is German for "Don't get your fingers caught in the fan belt"
Cylinder layout:
flywheel
3 - 2
4 - 1
crank pulley
Old 04-25-2005, 09:57 AM
Detached Member
Hugh R's Avatar
Had it completely wrong on the firing order, thanks Wide!
Hugh
Old 04-25-2005, 10:11 AM
"Zunde" = ignite, "folge" = sequence. Pay particular attention to Thom's diagram; cylinders are numbered different (backward, kinda) from our 911's. This tripped me up when I first got into 911's. I have always set my valves at .10mm (.004"). .006"-.008" gets pretty noisy, although it probably won't hurt anything. Check and see if he is running a full mechanical advance distributor, like the Bosch 009. It's a very popular conversion and the timing specs are different for it than what the '72 manual will call out for the standard vacuum advance it came with. I go 7.5 btdc with the 009.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 04-25-2005, 10:12 AM
Double Trouble
targa911S's Avatar
When it comes to valve settings...better to hear them than to smell them.
75 914 1.8
2010 Cayenne base
Old 04-25-2005, 11:48 AM
Ahem, I do believe the engine cylinders are oriented this way-
flywheel
3 1
4 2
The cylinder numbers are stamped right into the tin if you have any doubt.
Old 04-25-2005, 07:56 PM
You are right Ed; I've been looking at the 911 too long again. Front to back, right to left on the Bug, back to front, left to right on the 911. Why on Earth did they do that? I've taken to writing the cylinder numbers on the distibutor caps with a felt pen just because of this nonsense. The old one doesn't come off until the new one is written on and looks just like it. I don't know how many times I have reversed this in my head. It sure was easier when all I had was Bugs...
Jeff
'72 911T 3.0 MFI
Old 04-25-2005, 08:58 PM
Hey it's really easy to make mistakes, I know I make my share of them. Just recently I purchased what was advertised as a 1600 VW engine as a temporary engine for my 356 project. Once I had it home I was showing it off to my friend who immediately recognized it to be a good old 40 horse (1200). To boot it had problems and I ended up rebuilding the top end with a 1500 big bore kit. I kind of wish I had just cut my loss and found a proper 1600 and added cylinders to that. Oh well, the saving grace is that I only spent $200 for the engine and it had a 6volt flywheel to match the starter. I guess those are hard to find. Absolutely no regrets about purchasing the car though! The engine and flywheel did bolt right in nd the engine has a surprising amount of power for what it is. If anybody had a line on a 356 or 912 engine reasonably priced, let me know.
Old 04-25-2005, 09:36 PM
Detached Member
Hugh R's Avatar
Thanks guys!!!
Timing on the distributor was way off like 30 degrees! No. 2 plug wire was dead, Point gap was way open like 15 degrees of dwell. Told the boy to buy a Muir VW book and that I'll see him in the morning.
Hugh
Old 04-27-2005, 09:31 PM
Double Trouble
targa911S's Avatar
Johns book is a good read. He was (RIP) a pretty funny man.
75 914 1.8
2010 Cayenne base
Old 04-28-2005, 09:27 AM
