In the shop at Pelican
Jared at Pelican Parts's Avatar
Need a steel rim and hub for a 71 VW bus
anyone out there got a original steel rim and a front hub for a 71' VW bus? I dont care what condition the rim is in, as long as it is straight. Been working on a bus that someone used a welding torch to remove a siezed lug nut. needless to say, the rim and the hub are wasted, and it's only using 4 lug nuts. (yes he is driving it around this way, he's a surfer and a college student)
These have to be a pretty common part out there...
Old 04-29-2005, 09:50 AM
By "hub" do you mean "brake drum"?
Hit up ronnie@type2parts.com
Old 04-29-2005, 10:24 AM
id10t's Avatar
Check with Jim at EASY - www.easypor.com
Old 04-29-2005, 10:56 AM
chibone_914's Avatar
Nope, 1971 is the first year of front disc brakes. No drum brakes here.
Jared needs the 5-bolt hub that holds the front brake rotor. Try your local pick-ur-part. Same hub from 1971-1979 type II
Thank you!
John
johnechi@hotmail.com
Old 04-29-2005, 02:26 PM
Student of the obvious
LeeH's Avatar
Have you looked here:
http://www.thesamba.com/vw/classifieds/cat.php?id=25
Lee
Old 04-29-2005, 02:49 PM
Ya know, I should have known that, but I guess I just ignore everything past '67
Old 04-29-2005, 03:00 PM
