In the shop at Pelican
Need a steel rim and hub for a 71 VW bus
anyone out there got a original steel rim and a front hub for a 71' VW bus? I dont care what condition the rim is in, as long as it is straight. Been working on a bus that someone used a welding torch to remove a siezed lug nut. needless to say, the rim and the hub are wasted, and it's only using 4 lug nuts. (yes he is driving it around this way, he's a surfer and a college student)
These have to be a pretty common part out there... |
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Check with Jim at EASY - www.easypor.com
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
Nope, 1971 is the first year of front disc brakes. No drum brakes here.
Jared needs the 5-bolt hub that holds the front brake rotor. Try your local pick-ur-part. Same hub from 1971-1979 type II
Thank you! John johnechi@hotmail.com |
Student of the obvious
Have you looked here:
http://www.thesamba.com/vw/classifieds/cat.php?id=25
Lee |
