The Unsettler
stomachmonkey's Avatar
convert grill from NG to LP help
My in-laws are moving to FL. and gave me their Weber Genesis grill. My old grill was toast and needed replacing this year so it was a welcome gift.
In-laws used it with the natural gas at their house and I do not have NG at my place.
Figured I would just buy a new regulator and use my existing LP tanks.
Come to find that there is a difference in flow rates between NG and LP and Weber says I need a new manifold. OK fine no big deal, $65 bucks to upgrade a $700 grill seems fair.
Problem is it seems to be Weber only direct part, they are out of stock and I have a big party this Saturday for my son's 2nd b-day and now no grill.
Any thoughts, suggestions? Maybe one of you has an LP manifold for a Weber flaoting around?
Never hurts to ask.
Scott
"I want my two dollars"
"Brandon Won"
Old 05-26-2005, 08:17 AM
Perhaps you can try a Weber parts reseller. Hopefully thay stock inventory and don't merely drop ship.
http://www.clagrills.com/parts/weber/weber-parts-home.htm
http://www.weberstuff.com/webreppar2.html
http://www.grillstuff.com/webgrilac.html
Warren & Ron, may you rest in Peace.
Old 05-26-2005, 09:26 AM
The Unsettler
Thanks Rick,
I already tried those guys.
Looks like I'm SOL.
Scott
"Brandon Won"
Old 05-26-2005, 09:37 AM
Scott, which exact model do you have? There are many versions of the Genisis. I can call a couple of large supply houses that are local.
Old 05-26-2005, 09:42 AM
Somewhere in the Midwest
MotoSook's Avatar
Are the NG manifold holes smaller or larger than the holes in your old grill? I think bigger...if you want to play with fabricating your own, just get some tubing or pipe to match the old manifold, drill holes, cut old manifold, slip new tubes over the stubs you left of the old manifold, tack weld...get a propane regulator...
... if holes are smaller...enlarge them..
..if you need a new regulator, get one from one of those turkey deep fryers...it's adjustable and you can really crank you new grill to heat up fast using the adjustable regulator
Anything after the regulator is low pressure so you can cut and couple the hoses...
...yeah...so I'm crazy like that, but then I'm use to working with higher pressures try 1200 PSIG!
Old 05-26-2005, 11:04 AM
greglepore's Avatar
The NG orifices are larger than lpg, it'd be a pain to reverse engineer this for a weekend or two's use.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 05-26-2005, 11:31 AM
MotoSook's Avatar
a weekend or two?...oh man...I use my grill 2-3 times a week when the weather allows.
...and what fun is it to just swap out manifolds
Old 05-26-2005, 11:38 AM
Cars & Coffee Killer
legion's Avatar
Not to start a p!$$ing contest, but try playing paintball (you're not far from Tri-City Paintball, Souk). A day of running, jumping, and sliding with a 4500 psi tank next to your head.
Here's the quickest and easiest way to fix your grill:
1) Remove all of that NG tubing and such.
2) Go buy a bag of Charcoal. It tastes much better!
(I just had a slow-cooked, smoked duck for dinner last night that I cooked on our 25-year old Weber.)
5 liters of VVT fury now
-Chris
Old 05-26-2005, 12:12 PM
MotoSook's Avatar
But your CO2 won't blow up and take out a subdivision
Old 05-26-2005, 12:25 PM
legion's Avatar
True Souk.
I use N2, CO2 will only get up to about 1300 psi in a tank before it turns to liquid at operating temperatures.
-Chris
Old 05-26-2005, 12:30 PM
The Unsettler
You guys are SICK!
Thanks for the advice, I think.
Rick, appreciate the offer, very generous of you.
I've got it sorted for this weekend.
Turns out the regulator on my old bbq went tits up. Home Depot+$20=grilling this weekend.
I'll order the new manifold from Weber and when it gets here it gets here. Till then I'll still have the old one.
Have a GREAT weekend and thanks.
Scott
"Brandon Won"
Old 05-26-2005, 03:41 PM
