Airbus A380 Issue
From an email I received. The email went on to say that they also saw some signficant deflections in the main gear struts under these loads. The photo below shows what happens when you turn an A380 on the tarmac:
AirBus elected NOT to make their main landing gear system (four separate gear with four wheels apiece) steerable. Why? You save a considerable amount of weight -- not to mention some serious extra cost -- by not doing so. There is a trade-off, however ...
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Another pic:
Send it down to Tyson @ TRE for some adjustments...
Is that the pavement that's chewed up, or is it leaving that much rubber behind?
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
That's chewed up pavement. I'm sure airport operators will love to see that.
Mike
I'm not an aerospace engineer - and I don't play one on TV - but it seems like frickin' common sense to make something that big steerable.
There's a picture out there of some big cargo plane landing, and it's gear are pointing one way and the plane is pointing another. Maybe SingPilot and others can shed some light.
Well for sure all aircraft tires take a royal beating in these situations, but it seems the massive size of the A380 is really exacerbating the problem.
Like you said, I'd like to hear feedback from the guys who know more about this. Mike
I'm with Bill
Oh my God!! Those tires are Michelins! The sidewalls are going to fail!! I am suprised Micheline has not sent a letter advising not to use the tires yet.
1978 Mini Cooper Pickup 1991 BMW 318i M50 2.8 swap 2005 Mini Cooper S 2014 BMW i3 Giga World - For sale in late March |
I'm off the hook.....
I just assumed the French aircraft design team wanted to sell French tires. Almost (can't speak for the French designed types) every Pilot's Operating Handbook advises against locked wheel turns, for this very reason.
Those are pretty amazing pictures. Another (long list) reason to stay out of an Airbus.
No, I don't sing. Based there for too long. |
Information Junky
per PBS.org:
. . .doesn't everyone know that?
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
MAGA
I bet the problem is with the tug driver. Some one obviously tried to pivot the plane too sharply while ground positioning it.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Non Compos Mentis
A cousin is a mechanic on both Boeing and Airbus airliners. The term around the maintenance base is "Scarebus".
Mike
What does this say about the rest of the plane (engineered from the ground up)?
Peter '79 930, Odyssey kid carrier, Prius sacrificial lamb Missing 997.1 GT3 RSnil carborundum illegitimi |
MAGA
I could give a rats butt about Airbus vs Boeing, but many aircraft can be damaged due to improper ground handling. Many aircraft have to have pins pulled on linkages, etc and published procedures followed before being towed by tugs. The skid marks obviously show that the plane was being improperly pivoted about that gear leg, it does not neccesarily have anything to do with the design of the aircraft.
The tugs have the ability to move the aircraft even with locked brakes, or to pivot it with the gear scrubbing just like in the pictures. I suspect that is the case with these pics. You'll note these pics are from Airbus (copyright notice in lower right corner), so they are probably using them to illustrate what NOT to do, and to document the damage.
MAGA
When the nose gear is pivoted 90 degrees and pushed or pulled at that angle, the inside main gear has to pivot, while the outer gear can roll around the larger radius. This is like when you are trying to turn sharp with a tractor. You stomp on the inside wheel brake and pivot around meanwhile, the inside wheel has to skid as it is not rolling.
What Tom said above is true about some aircraft, but by no means is this the majority. I doubt this kind of ground handling is required at most airports (severe pivoting turns).
What makes this plane different, is that there are 4 main gear trucks. Even if one truck pivots, the other is scrubbing. Looking closely at these pics (you can see which direction is forward and aft), this pivot happened with the plane moving backwards, meaning it was being pushed with a tug. Yes, this kind of manuvering is not required at any major airport, and in fact the handbooks give the minimum turning radius and maximum angle allowed on the nosegear.
This is what happenes when the book is not followed.
So why not make all or some of the gear trucks steerable?
Some of the airports (eg/SFO, SeaTac) have pretty tight confines. In fact, if my sense of proportion is not out, getting this plane to an interior gate at Atlanta is going to require fairly tight turns.
