Question concerning Axle Ratio
Which axle ratio provides the lower engine rpm at the same driving speed assuming that the transmissions are identical: 3.73 or 4.10?
I have always been under the impression that the larger that the axle ratio was the lower geared the vehicle was. I am looking into purchasing a truck and in reviewing the sales brochure the following data is stated - for an axle ratio of 3.73 the maximum loaded trailer weight is 2,640 lbs whereas an axle ratio of 4.10 is 2,500 lbs (which contradicts my previous assumption). Since I will not be hauling anything on a regular basis I want to have the most economical platform. I am currently looking at a Ford Ranger Edge - any input here would be appreciated also.
Daryl G. 1981 911 SC - sold 06/29/12 Last edited by fireant911; 08-10-2005 at 02:14 PM.. |
3.73. The lower the number numerically, the "taller" the ratio. Your impression is correct.
Rear end ratio isn't the only thing that affects towing, but you're right, I would expect the 4.10 rearend to tow a little better. Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
