Hooking up phone to computer that has DSL, is it possible?
Hi, stupid computer question here. I have recently moved my home office to a room in my detached garage. I have run a DSL line out to the garage (wireless wouldn't work), and was wondering if there was a way to get phone service from the DSL line, through the computer. Sure, I have a cordless phone and a cell, but the cordless gets crappy reception in the garage (garage office is about 75-100 feet from phone base), and cell phones are iffy sometimes.
Do I need to just run a line out here, or can it be done? TIA, Jim |
If I'm thinkin' right... Just split the line, put a filter on, then go into the phone.
1972 911T 1972 911E "RSR" |
Slackerous Maximus
Unless you are on some old school 2 line setup, skipdup is right. Just put a splitter on, and put a filter on so the phone does not get static. Splitters (and long cable runs for that matter) degrade the signal, but unless you are gaming/mp3 fanatic it probably won't effect your life.
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
First, thanks for the responses.
Now, I will continue on with my computer illiteracy: I ran a DSL hard line to the garage. This is different from a phone line, as far as I can tell. Is there a splitter that will send the DSL line to the computer, and the phone line to the phone? (maybe a trip to Radio Shack?) Or do I need to actually tap into the line? BTW, I'm not into gaming (the last game I spent any time on was Asteroids), and I barely know what an MP3 player is. All I'm looking for is a decent phone line. Thanks again, Jim |
When you say different are you referring to an 8 position jack vs a 4-6 position jack? The actual cable can be the same for either application (4 pair, CAT 3 or better)...neither application requires all 4 pairs...
923/912E (2.1l OEM EFI '99 F150 4x4 Chipped (who cares) LLVL in the LBC... "Long Hoods Rule" "RICE - The Breakfast of Champions" |
If you want to use your DSL for phone ( no phone bill )
there are physical phones that use free VOIP ( voice over Internet Protocol ).. Your DSL only uses 2 wires in the jack. If you are looking to just add another extension to your existing.. look here for an example of a phone that uses your dsl again, it's just one example.. I will probably be picking up one of these myself Don
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat Last edited by Don 944 LA; 09-12-2005 at 03:11 PM.. |
Blockchain Tech Inventor
Jim - sounds like you just pulled a RJ-45 (Cat 5) cable from your hub/router/DSL modem out to the garage - right? So, unless you want to go with something like VOIP, I would just pull a phone cable along with that Cat 5 cable.
A Mean Green Lifted 1972 C10 Long live the king! |
Thanks again. The Radio Shack dude just told me the same thing as jrdavid68 did. To clarify, I did indeed pull a cat5 cable from the indoor router. Looks like I'll have to put a cable out here. Oh well.
VOIP sounds interesting, I'll have to check that out. Jim |
