Super Moderator
Hows this work then?
Some sort of mathematical projection or general assumptions on human reactions?
http://trunks.secondfoundation.org/files/psychic.swf
limited number of possible answers. they all have the same symbol. each time you 'try again' they have a new symbol, but are all the same.
also note that other numbers that are not possible will have the same symbol as the possible numbers to mix things up a bit. -bernie
Database and Website Consulting Services in Chicago |
I can't figure it out.
I guess I'll have to wrap my head in aluminum foil to keep the machine for scanning my brain.
Sheena is a punk rocker Suzy Is A Headbanger Heidi Is A Headcase Judy Is A Punk The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'." |
Every possible answer is a multiple of 9. Look at the chart, all the multiples of 9 share the same symbol. (9, 18, 27,36,45...)
When you click "try again", the symbols change, but once again all the multiples of 9 share a common symbol.
vott does ziss do?
exactly. even simpler than a forced-choice questionnaire
Super Moderator
...so Moses I can take the aluminum foil off my head now?
vott does ziss do?
yes. all clear
