-   -   I dont want a hood scoop! Help (http://forums.pelicanparts.com/off-topic-discussions/245871-i-dont-want-hood-scoop-help.html)
TerryBPP 10-13-2005 10:02 AM
I have been working on a 318i M10 turbo for some time now and have run into a small problem. I used the stock manifold, flipped it upside down, and made an adapter for the T3 flange. I made the adapter as low as possible, theres just enough room to tighten the nuts.
Problem is the turbo touches the hood when its closed. Its going to burn the hell out of it. So I need to raise the hood in that section (4" x 4"). I dont really want to put a ricer scoop on one side of the hood. Anyone see any nice looking way to do this?
cstreit 10-13-2005 10:07 AM
Can you subtly flare the hood a bit and add some cermic insulating material? It's a lot of work but will save you the hood scoop.
pwd72s 10-13-2005 10:09 AM
Instead of a scoop, how about a "bubble"? Those beautiful long nosed cars of the early 60's did it all the time...hoods with mysterious bumps on them...usually for carb clearance.
TerryBPP 10-13-2005 10:15 AM
I would love to do this but I need to find a hood that I can cut the bubble off of and weld it to mine. Any ideas? Didnt a little Dodge car have a turbo bumo?
pwd72s 10-13-2005 10:25 AM
If doing it yourself, I'd suggest making a rough design out of cardboard...then visit a Detroit car wrecking yard & start matching curves...you might find what you're looking for on a crumpled trunk lid corner, a fender curve, wherever. If that panel has been hit, the wrecked-em yard would sell it for next to nothing...
Tim Hancock 10-13-2005 10:28 AM
Terry, I would think about cutting a circle in some particle board then throwing a sheet of old truck tire inner tube on it. Next find a hard large ball (bowling ball maybe?) then carefully postion the hood over the hole and smack the ball with a large mallet thus cold forming the bubble into the hood. If the paint is warmed first it may not even crack. I would experiment on a scrap pc of sheet metal first though and be sure to size the hole properly.
Vipergrün 10-13-2005 10:32 AM
Actually, I do not think a little scoop like on the WRX's looks too bad. IMHO, a bubble may look a little odd, but you could probably find one to use from like a Turbo Mitsu Eclips or similar, didn't they have one?
TerryBPP 10-13-2005 10:42 AM
LOL, I always wondered why that guy purposely put that turbo that high. He could have obviously cut atleast a foot off of it.
Anyway, I just came across a cool little scoop.
http://forums.pelicanparts.com/uploa...1129225297.jpg
Tim, you're a nut.
304065 10-13-2005 10:49 AM
Terry, I would steer clear of a power bulge. The whole POINT is to make people think that you have a bone stock 98 hp four-banger under there!
If it were German taxi yellow with a 324d badge, more the better.
http://home.att.net/~jroal/jay/bmw.htm
http://home.att.net/~jroal/jay/clints.html
TerryBPP 10-13-2005 10:58 AM
Ahh, you found my reference site. Only difference is he mounted hi turbo below the mani. I couldn't do that because my is so low ,bilstien shocks, ie springs, ie sways, 3" drop +/-. The outlet to the turbo would hit the ground, lol. You also need an insane amount of intercooler and charge piping. Here is mine:
http://forums.pelicanparts.com/uploa...1129226168.jpg
It sits about 2" higher than in the pic.
With the stance, brakes, 15" Kosei wheels (14 lbs!) this thing looks anything but stock.
M.D. Holloway 10-13-2005 11:03 AM
Any chance of actually raising the entire hood? Put on a side panels where the hood meets the fenders.
BTW - I like the lil scoop you found.
928ram 10-13-2005 11:04 AM
Terry, is it hitting the outer skin of the hood or some of the inner bracing? Would some sort of grill-type panel painted with hi-temp paint and flush (or close to flush) mounted work?
Several of the FWD Chryco cars used a low profile "bulge"; Daytonas and Shadows had them as well as a couple of the Omni hatchback cars probably some others.
TerryBPP 10-13-2005 11:21 AM
I wish it was hitting a brace. Sitting on the skin.
I thought about cutting a duct and just putting a mesh on it but I fear the turbo would cook that too.
TerryBPP 10-13-2005 11:24 AM
I think this is what you where thinking?:
http://forums.pelicanparts.com/uploa...1129227854.jpg
Moses 10-13-2005 11:25 AM
Go with something classy like this;
http://forums.pelicanparts.com/uploa...1129227933.jpg
Moses 10-13-2005 11:31 AM
Didn't the Ford Probe have a small bump in the hood? Might be a suitable graft.
bryanthompson 10-13-2005 11:32 AM
eagle talons have a small bump.
928ram 10-13-2005 11:33 AM
Yeah something like that to keep the lines clean. Since it's hitting the outer skin, even something like that wouldn't work because engine movement would bust it out. Looks like either a bulge or scoop is the way to go.
A NACA duct would work, but would probably look stupid with a turbo in the middle of it.
Tim Hancock 10-13-2005 11:35 AM
Originally posted by TerryBPP
Tim, you're a nut.
Actually I was being serious, but obviously there are plenty options available if you are going to cut the hood.
TerryBPP 10-13-2005 11:57 AM
Jesus, I thought you were kidding. How tall a ladder do I stand on?
