I dont want a hood scoop! Help
I have been working on a 318i M10 turbo for some time now and have run into a small problem. I used the stock manifold, flipped it upside down, and made an adapter for the T3 flange. I made the adapter as low as possible, theres just enough room to tighten the nuts.
Problem is the turbo touches the hood when its closed. Its going to burn the hell out of it. So I need to raise the hood in that section (4" x 4"). I dont really want to put a ricer scoop on one side of the hood. Anyone see any nice looking way to do this? |
Super Moderator
Can you subtly flare the hood a bit and add some cermic insulating material? It's a lot of work but will save you the hood scoop.
Instead of a scoop, how about a "bubble"? Those beautiful long nosed cars of the early 60's did it all the time...hoods with mysterious bumps on them...usually for carb clearance.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
If doing it yourself, I'd suggest making a rough design out of cardboard...then visit a Detroit car wrecking yard & start matching curves...you might find what you're looking for on a crumpled trunk lid corner, a fender curve, wherever. If that panel has been hit, the wrecked-em yard would sell it for next to nothing...
MAGA
Terry, I would think about cutting a circle in some particle board then throwing a sheet of old truck tire inner tube on it. Next find a hard large ball (bowling ball maybe?) then carefully postion the hood over the hole and smack the ball with a large mallet thus cold forming the bubble into the hood. If the paint is warmed first it may not even crack. I would experiment on a scrap pc of sheet metal first though and be sure to size the hole properly.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Formerly bb80sc
Actually, I do not think a little scoop like on the WRX's looks too bad. IMHO, a bubble may look a little odd, but you could probably find one to use from like a Turbo Mitsu Eclips or similar, didn't they have one?
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
LOL, I always wondered why that guy purposely put that turbo that high. He could have obviously cut atleast a foot off of it.
Anyway, I just came across a cool little scoop. Tim, you're a nut. |
Terry, I would steer clear of a power bulge. The whole POINT is to make people think that you have a bone stock 98 hp four-banger under there!
If it were German taxi yellow with a 324d badge, more the better. http://home.att.net/~jroal/jay/bmw.htm http://home.att.net/~jroal/jay/clints.html
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
It sits about 2" higher than in the pic. With the stance, brakes, 15" Kosei wheels (14 lbs!) this thing looks anything but stock. |
Targa, Panamera Turbo
Any chance of actually raising the entire hood? Put on a side panels where the hood meets the fenders.
BTW - I like the lil scoop you found.
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
Terry, is it hitting the outer skin of the hood or some of the inner bracing? Would some sort of grill-type panel painted with hi-temp paint and flush (or close to flush) mounted work?
Several of the FWD Chryco cars used a low profile "bulge"; Daytonas and Shadows had them as well as a couple of the Omni hatchback cars probably some others. |
I thought about cutting a duct and just putting a mesh on it but I fear the turbo would cook that too. |
I think this is what you where thinking?:
Go with something classy like this;
Didn't the Ford Probe have a small bump in the hood? Might be a suitable graft.
eagle talons have a small bump.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit |
A NACA duct would work, but would probably look stupid with a turbo in the middle of it. |
MAGA
