H.G.P.'s Avatar
Computer: What is C:\Windows\Temp ?
What is the function of this folder?
I see there are items in this folder. Should they be left alone?
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 12-17-2005, 10:54 PM
slodave's Avatar
You can delete the items. It may have been a folder created when you installed certain programs. I often create the folder myself when needing a temporary folder to keep downloaded drivers.
Dave
Old 12-17-2005, 10:57 PM
H.G.P.'s Avatar
OK, one of my computers the folder is filled with items. Thanks.
1969 911 E Coupe
Old 12-17-2005, 11:00 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
It should be cleaned out regularly. Windows is too stupid to delete all the temp files it creates for many applications. I've literally seen computers with like 600MB worth of old temp files and crap in that folder. . . It slows things down a LOT.
The newer releases are better, BTW, but it should still be checked periodically and if necessarly, purged.
Black Cars Matter
Old 12-17-2005, 11:07 PM
Senior Member
HG,
You know that when you delete items out of the "temp" directory that you are not really deleting them yet?
You have to clean out the "recycle" bin and after that its a good idea to "defrag" the hard drive, especially if its been a while since doing so or if you have deleted a large number of files.
JoeA
Old 12-17-2005, 11:54 PM
H.G.P.'s Avatar
Originally posted by Joeaksa
HG,
JoeA
Yes, I noticed that, and the r-bin is right on the d-top. One of my temp folders has items dating back to 1999.
1969 911 E Coupe
Old 12-18-2005, 10:17 AM
84porsche's Avatar
Send a message via Yahoo to 84porsche
Wanted to add to the question, hope you don't mind H.G.P. - what is this temp folder ...
C:\Documents and Settings\user\Local Settings\Temp
and can these be cleaned out as well?
Modes of Transportation:
1984 Porsche 911 Targa
2003 VW Jetta GLI
Old 12-18-2005, 10:25 AM
slodave's Avatar
The stuff in there can go as well...
Dave
Old 12-18-2005, 06:40 PM
John Rogers's Avatar
You might try this to clean things out: Go to start -> Run -> and then type in %temp% in the space and press OKAY. When the window appears, marl everything and delete them. You might be surprised how much is on your PC.
Old 12-18-2005, 07:06 PM
Rob Channell's Avatar
If you hold down the Shift key while deleting files they will just be deleted instead of moved to the recycle bin.
Rob Channell
One Way Motorsports
1979 911SC mostly stock
1972 911T Targa now with a good 2.7
1990 Miata (cheap 'n easy)
1993 C1500 Silverado (parts getter)
Old 12-18-2005, 10:05 PM
