Targa, Panamera Turbo
Setting Up a Garage, List Out The Tools...
Ok, say you are going to become a wrench - a mechanic. While I know its rather open ended (like the wrench - I know, bad pun), list out the tools and the approximate cost to set up your garage for the tools you would need for either diesel or gas. Things not to worry about would be compressed air or welding supplies or a lift. Lets say the company will take care of that. What they won't cover would be the box, the tools (wrenches, sockets, etc...), the power tools and the accessories.
How much do you think all this would cost to sort out a functioning garage? $!0,000? For instance (from a few different sites): Tool Box - Roll Away with Key Lock Socket Set - 1/4" Drive •3/16" - 1" Standard Depth (6 Point) •3/16" - 1" Deep (6 Point) •5mm - 19mm Shallow (6 Point) •5mm - 19mm Deep (6 Point) •Ratchet •Extension - 3", 6", 12", 18" •Flex/Universal Joint Socket Set - 3/8" Drive •5/16" - 7/8" Standard Depth (6 Point) •3/8" - 7/8" Deep (6 Point) •8mm - 19mm Standard Depth (6 Point) •8mm - 19mm Deep (6 Point) •Ratchet •Extension - 3", 6", 12", 18" •Universal Joint •Fractional Universal Impact Socket Set 3/8" - 7/8" (Rec mid-depth) •Metric Universal Impact Socket Set 9mm - 19mm (Rec mid-depth) Socket Set - 1/2" Drive •7/16" - 1 1/8" Standard Depth (6 Point) •7/16" - 1 1/8" Deep (6 Point) •10mm - 25mm Standard Depth (6 Point) •10mm - 25mm Deep (6 Point) •Ratchet •Breaker Bar •Extension 3", 6", 12", 20" Combination Wrenches •1/4" - 1 1/4" Standard •7mm - 24mm Metric Tubing Wrenches •3/8" - 3/4" •10mm - 18mm Hex (Allen) Wrenches •050" - 3" Fractional •2mm - 22mm Metric Screw Drivers Blade Type •Stubby •Pocket Screwdriver •1/4" x 6" •1/4" x 9" •3/8" x 9" •3/8" x 16" •Offset Phillips •#2 Stubby •#1 Tip •#2 Tip •#3 Tip •Offset Torx Bits Tamper Proof (Screwdriver or Sockets) T-8, T-10, T-20, T-25, T-27, T-30, T-40, T-50, T-55 Pliers •Slip Joint 6" •Needle Nose 6" •Diagonal Cutter 7" •Channel Locks 12" •Duck Bill Pliers 7 3/4" (ex. snap-on # 61ACP) •Vise Grip Pliers 10" (10WR) Snap/Retaining Ring Pliers •Internal Retaining Ring Pliers •External Retaining Ring Pliers •Snap Ring Pliers (ex. Snap-On SRP2 style) Files with Handles •Flat 10" Mill Bastard •Round 8" - 10" •Three Cornered Hammers •16oz Ball Peen •160z Soft Faced Dead Blow •Hand Drilling 3 to 4 lb. Punch and Chisel Set •Center Punch •Pin Punch - 1/8", 3/16", 1/4", 5/16" •Taper Punch 3/8", 1/2", 5/8" •Brass Punch - 3/4" •Cape Chisel - 5/16" •Cold Chisel - 3/8" - 3/4" Pry Bars •Rolling Head 16" •Straight 16" Brake Service Tools •Brake Spring Pliers •Spring Hold Down Tool Safety Equipment •Safety Glasses •Hearing Protectors (recommend ear muff type) Electrical Tools •Digital Multi meter (Rec Fluke 87,88 or 1587) •Powerprobe Electric Circuit Tester •Wire Stripper/Cutter Pliers 8" (ex Snap-On PWCCS8) Small Tools •Pocket Knife •"O" Ring Pick Set •Inspection Mirror •Spark Plug Feeler Gauge (gap tool) •Feeler Gauge (Blade type) •Flexible Pick Up Tool (magnetic and claw type) •Tape Measure 12" •Hack Saw Special Tools •Torque Wrench - 1/2" Drive (Snap-On Quality) •Micrometer - 0-1" or dial caliper 0-6 •3/8" Drive Air Ratchet •1/2" Drive Air Impact Gun •Socket Set - 1/2" Drive Drive Impact 1/2" - 1" •Pry Bar Screwdriver style 30" or larger •Hand Operated Vacuum Pump •Compression Gauge •Feeler Gauge (Go-No-Go, blade type) Power Tools to include corded and cordless drill metric and Eng bits, impact drill, air tools, sawzall, I'm sure I'm leaving stuff off...
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
The Unsettler
Don't forget for a lot of that stuff you need at least double.
By "tube wrench" I assume to mean a line wrench. I've never needed one over 1/2"
You only list a 1/2" torque wrench, you would want a 1/4" and 3/8".
An some sort of vacuum tool for bleeding brakes. I would also add a 'fox & hound' under electrical, along with a soldering iron.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Metric and SAE tap and die sets
Metric and SAE thread files Metric and SAE nut driver sets Oxy/acetyline torch small butane torge electric heat gun gear pullers
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
The newest of the noobs!
3/4" air wrench is something to consider for those pesky crank bolts. And, if you are not detail-oriented, two of some of the common sizes are nice to have. In both wrenches and sockets, 6,7,8,9,10,13,17,19mm. Long philips screwdriver for 944 air box screws, T-handle hex wrenches, Go-Jo hand cleaner.
1989 944 Turbo 2004 Jeep Wrangler Unlimited - Built! 1985 Saurer 6dm overland Swiss military truck/camper |
1988 Carrera
D idn't E arn I t
huge air compressor, rotary cutting wheel, sawzall, sledgehammer. Spring compressors for struts. GOOD torque wrench 3/8 drive.
Make sure you buy a long handle ratchet in 3/8, same with your combo wrenches- LONG handles, and 1/4" flex head rats. various files, tools to pick, poke and prod help too. Not sure if you need the duplicate sizes in 1/2"- truthfully, on a passenger car I rarely use 1/2. Whatever sizes you don't have in 3/8 get in 1/2 instead. also, maybe 12 point SAE if you are playing with hotrods- in 1/4 drive, up to 9/16" rjp
In the movies only bad guys sleep in king size beds. |
A good used snap-on tool box on craigslist will run in the neighborhood of $2,500 to $5,000+.
Didn't see any scan tools on your list. That's some coin. You will also need a big sign on the box telling the other wrenches that "Fingers that touch my tools will be added to my collection..."
bunch of random cars and bikes. |
Other things that are handy to have on hand:
A full easy-out set for extracting broken bolts. small maglite flash light scissors/sheers steel brushs zip ties deburring tool hand scraper socket step down adapters 3/8"-1/4". 1/2"-3/8" |
My guess is that you could spend $20k-50k on tools if you bought new and of pro quality (not HF or Craftsman) and everything that you might need.
1966 - 912 - SOLD
a computer or laptop so you may get to the glory of the Pelican!!!!
i was too tired to be pretty last night! |
Just come and buy my top & bottom boxes
![]() Even have Whitworth sizes. Jim
down to jap bikes that run and a dead Norton |
It would be interesting to get a reply from an active professional mechanic. I would guess 50K as a start point with tools. Any mechanic that has worked for long will have way more than that invested in a few years. I know some long term pros that have several large tool boxes of stuff. It will all depend if you are going to stay with one make of car or multiple brands foreign and domestic.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I've had good luck on Ebay looking for used tool lots. Got interested in woodworking and found a guy retiring and selling out his whole shop (planer, joiners, band saw, table saw, a billion hand tools). I've also bought chests full of automotive tools. If you don't require new and shiny, it is a good way to get started.
