Friends of Warren
how to resize (reduce) digital images
I used my wife's Canon 20D to shoot some pictures of my car.
The files even when shooting in JPEG are around 3mb. When uploading to the Pelican BBS the files are way too big and get stopped. I used Windows Paint to resize the picture and the files get much smaller but the quality of the pic is reduced dramatically. On the BBS I have seen very good qual pictures... how do you do that keeping the files small? |
Friend of Warren
There are some really good software programs out there for free that do a great job of resizing. I use IrfanView. Google it and you will find a place to download if from. I would also change the quality selector on your camera. For pictures on the computer you really can't tell a difference between the medium and high settings.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Work in Progress
Do you have Microsoft Office Picture Manager? ? ? That is what I use. try to right click on one of your pictures and go about half way down the list of options to "open with". A list of programs that you'll be able to open the picture with should be there. If Microsoft Office Picture manager is there open it with that. Then when the picture is opened with picture manager click on "edit pictures" on the top tool bar. Then a window will open on the right side of the screen and at the bottom of the list of options select "compress pictures." Once there I typically choose to compress the pictures to "document" size and that should do the trick.
I've got windows XP professional and added Microsoft Office and my computer has it so maybe you do too. When I double click on pictures though it used to open in windows paint too so it took a little bit of luck for me to find the program. Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB -Marine Blue '87 930 |
Friends of Warren
Ha! my office at work does not have the picture manager...
My office at home does.. Trying to see if I can download it... otherwise I'll follow Kurt's suggestion and get IrFanView. Thanks! |
Edministrator
I believe IrfanView is probably the best free image software out there.
Good post? Leave a tip! O - $1 O - $2 O - $3 |
www.gimp.org
Free and free. And equal to Photoshop, if not better. Open your image with it, right click on it, pick image then scale then put in new width/height value, keep the ratio of w:h the same as the original.
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
Google Microsoft power tools. They have a good image resizer program that integrates into the OS. I believe it's only for Win XP. Works well, just right click and select resize picture. There's also a bunch of other free power tools available from Microsoft.
Jim '18, Ford F-150; '07, Lexus IS350; '01, R1100S; '80, R65; '76, Honda CB750 Four; '73, Ducati 750 GT; '70, VW Beetle; '65, BMW R60/2; '64, Triumph Bonneville; '64, MV Agusta 125 GTL; '60, BSA Gold Star; '55, R25/3 |
Friends of Warren
I have just dowmloaded GIMP at home... will do the same at work. Havent got around using it yet though...
Me like track days
File: My Pictures - if your pics are saved here
Right click Resize Pictures Select Medium Done.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Friends of Warren
Oh another question...
I used to have little thumbnails showing up when opening "My Picture"... Now the thumbnails have been replaced by the icon of the software I am using to open them (now a little bear or gekko or whatever for Irfranview). How do I go back to seeing the thumbnails? I must have several hundred of pic... and finding the right one has become difficult... |
Pick view from the top, then thumbnails
Friends of Warren
I know... but istead of the thumbnails I have the Jpeg icon or the icon of the software chosen to open the pics...
I believe you have to switch "opens with" to a Microsoft prog (EI, or picture and fax viewer) to get the thumbs. When you installed Irfanview, you must have installed it as the default viewer. (BTW, I believe the Irfan icon is roadkill)
BTW; I think MS just recently released a RAW utility or powertoy to work with that format, which is one the 20D can use too. |
....Right click any jpeg>properties>general> "Change" button by opens with.
I find that when posting pics to the web, it's often a balance between resizing and/or cropping and/or jpeg compression to get the best pics for viewing. |
Friends of Warren
I tried it all... Now I have thumbs of a sunset (open with picture/fax viewerr).
I am downloading the MS Raw viewer... Thanks for the heads up |
