Ethanol E-85 verses Hybrids
I caught Autoline Detroit on PBS this weekend. GM, Brazil and E-85...........very interesting stuff.
GM has one up it's sleeve?
http://wardsauto.com/ar/auto_detroit_put_tiger/index.htm
But the most intriguing aspect of ethanol is that few foreign auto makers offer E85-capable vehicles. So if it really catches on, it would hand Detroit’s Big Three a massive advantage in the marketplace. It’s been a long, long time since they’ve had such an opportunity.
Ford has one up it's sleeve?
http://www.thestar.com/NASApp/cs/ContentServer?pagename=thestar/Layout/Article_Type1&c=Article&cid=1140390609385&call_pageid=970599109774&col=Columnist971715454851
The down side of gas-electric hybrid cars has been cost and complexity. Now the U.S. environmental watchdog says it has found a simpler, cheaper hybrid technology for motor vehicles
Related Tech Site:
http://www.infinitebang.com/shepinc.com/
Old 02-21-2006, 09:36 AM
Where is that wrench?
EdT82SC's Avatar
Why does it have to be E-85 versus hybrids? How about a hybrid engine that runs E-85?
Ed T.
1982 911SC
Porsche Wallpaper
Old 02-21-2006, 09:52 AM
Lots of commercials featuring big SUVs...
Face it folks, there aint no free lunch. How much energy and chemicals and farmland to produce that 15% alcohol in the mix?
The reality of the situation is pure Newton. Less mass and you will use less energy.
Old 02-21-2006, 09:55 AM
I think it's 85%, with 15% gasoline to keep it from freezing.
In Brazil they use up to 100% because it does not get very cold down there.
Only two studies out of dozens says there is a net benifit in energy consumption using E-85.
E-85 = Ethanol 85%
Old 02-21-2006, 10:01 AM
Good question.............how about diesel hybrids for that matter?
Old 02-21-2006, 10:02 AM
Cars & Coffee Killer
legion's Avatar
And they were both funded by the farm lobby. All of the others show a net energy loss.
5 liters of VVT fury now
-Chris
Old 02-21-2006, 10:07 AM
David's Avatar
Mercedes has a prototype diesel hybrid. I guess they're the only ones since they have a clientele that could actually afford such a vehicle.
The big question on E-85 is how much petroleum product does it take to make it.
What do the hybrid owners do in a few years when the batteries die? Anyone have a cordless drill battery work for more than a couple years?
Old 02-21-2006, 10:08 AM
Bill is Dead.
cashflyer's Avatar
...Face it folks, there aint no free lunch. How much energy and chemicals and farmland to produce that 15% alcohol in the mix?...
Every time I see those damn commercials, or hear somebody saying that ethanol is the solution, I wonder if anyone does research any more.
Every single research paper I have read says that the production of ethanol for use in automobiles is worse for our ecology than the petroleum alternative.
Ethanol freezes at -40c.
Old 02-21-2006, 10:25 AM
legion's Avatar
Right, but:
1) It is politically popular. Who cares about actual science. It doesn't get in the way of the hysteria over human-caused global warming, why should it have any place here? Besides, "It will reduce our dependence on foreign oil.©"
2) The farm lobby is very powerful and they more or less dictate the farm subsidies they want to Congress and state legislatures. Look at all of the subsidies for ethanol production.
-Chris
Old 02-21-2006, 10:37 AM
Banned
There are a lot of papers that conflict on this. There are so many that say diffrent things. I am starting to think that we would break even.
Old 02-21-2006, 10:38 AM
Banned
You can find instructions online to brew your own bio-diesel.
Try it, then you could "reduce YOUR dependence on foreign oil.©"
Old 02-21-2006, 10:41 AM
canna change law physics
red-beard's Avatar
An acre produces 7110 lbs corn -> 328 gallons of Ethanol @ 77,000 BTU per gallon
Gasoline = 125000 BTU's per gallon
We presently use 221,156,237,500 gallons of gasoline per year
So we would need to replace it with 359,019,866,071 gallons of ethanol
To produce the required ethanol, 1,094,572,762 acres would need to be dedicated to this production.
US land area 9,631,418 sq km total
19.13 % arable land
1,842,490.2634 sq km arable
1 square kilometer = 247.105 381 467 acres
455,289,259 acres for agriculture available
So we have 1/2 the land we need to be self sufficient with ethanol, and this would require turning over _any_ land usable for agriculture to the purpose of fuel production including forests, state parks, areas for houses, San Francisco, New Jersey, etc. The entire Country would be 6 ft high corn stocks and we still wouldn't produce enough to replace half of our gasoline usage.
The above doesn't include fuel electric power generation, heating, or any other fuel source, just gasoline for transportation.
Methanol from Methane might be a better fit, but CNG would be better.
Natural Gas for Transportation (Hybrid electric would be good)
Nuclear Power for Electricity (and everything else)
James
Red-beard for President, 2020
Old 02-21-2006, 10:47 AM
EdT82SC's Avatar
No, but the Interstate battery in my 911 is 7 years old, and won't die. My plan was to replace it with a lighter battery once it dies, but I am still waiting. Also, I may be wrong on this, but I thought I read something that said the batteries on a new Toyota hybrid last for the life of the vehicle. Whatever that means....
Ed T.
1982 911SC
Porsche Wallpaper
Old 02-21-2006, 01:12 PM
They get new batteries....but it aint cheap. I believe hybrid manufactureres have a pretty comprehensice recycling plan for the consumed pack.
Warren & Ron, may you rest in Peace.
Old 02-21-2006, 01:42 PM
FrayAdjacent911's Avatar
Send a message via AIM to FrayAdjacent911
I like seeing people throw up tons of calculations that are geared to indicate we can't outright replace our total gasoline consumption without turning every square inch of land into a corn farm.
Though it may be true, those calculations are based on consumption RIGHT NOW.
With things changing, hybrid and more efficient vehicles, is our consumption going to stay the same? Go up? Go down?
What would happen if a cheaply available battery source were discovered that could enable a pure electric vehicle get several hundred miles on one charge were discovered?
I think the naysayers are only measuring against what exists TODAY, and are not factoring in changing and evolving technology of tomorrow.
Matt J.
69 911T Targa - "Stinky"
2001 Boxster "Stahlgewehr"
Old 02-21-2006, 01:48 PM
Hey, any pecentage bite we take out of OPEC is worth it to me.
Old 02-21-2006, 01:54 PM
Originally posted by FrayAdjacent911
I
If we acted on what we have today, that would be a great start:
If we built more nuclear power plants to the latest design..
If we had a gas tax going up $0.50 per year..
If we gave tax breaks to heat with hard coal & wood..
OPEC would cry.
Old 02-21-2006, 02:38 PM
red-beard's Avatar
It would be great, but....the power still has to come from somewhere.
If anyone thinks our power consumption is going to go down, think again. Our population is expanding. The world population is expanding, and getting 'richer' which means they use more power.
My point is that you are not going to get all of your power from bio-fuels. Not going to happen. We have a couple of choices, but Nuclear will be essential.
James
Old 02-21-2006, 03:00 PM
Carbon Emitter
jkarolyi's Avatar
Battery technology hasn't improved markedly in the past 50 years. Americans vote for larger and heavier vehicles with their dollars. Hybrids are false economy...people only buy them because of government subsidies. Hydrogen and Ethanol powerplants are a joke and a big waste of tax/research dollars.
Waste disposal problems.
Tax on the poor.
Horrible air pollution.
Face it...there's no cheaper, and relatively clean and safe, energy source than oil. And like Bush says we're addicted to it. That's right folks...WE are to blame.
Old 02-21-2006, 03:02 PM
Who is John Galt?
Rondinone's Avatar
corn ethanol has been around for decades, and it hasn't gotten anywhere because of the low yield per acre. The current excitement is about cellulosic ethanol, which is fermented from any cellulose (grass, wood, debris) using specialized enzymes.
The National Renewable Energy Lab has gotten the cost of cellulosic ethanol down to about $1.15/gallon.
15% gasoline is added because the flash point of pure ethanol is too high to start a cold engine.
We drive these clunkers at work that run on E85, and they sometimes stall when cold. Otherwise they drive like a normal car.
'79 911sc Targa
'02 slk230 kompressor
'84 Tamiya Falcon
A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship. The average age of the world's greatest civilizations has been 200 years.
Old 02-21-2006, 07:03 PM
