AirBorne!
Cat Scratched Paint - How To Fix
Cat jumped onto my silver 911 coupe, missed his landing spot and slipped down the drivers rear fender. There are four distinct claw marks about 4 inches long. The scratches appear to only be in the clear coat.
I tried photographing the scratches to post here, but I couldn't get them to show up. My wife thinks its not a big deal and I should kill the cat. The cat's time is probably up and will meet its fate soon, we live near a busy road. Ooops. How do I fix the scratches? wj
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1975S to 1970s w 3.0 PMO - Roxanne, 1967 911 normal w 2.2s engine w S goodies, 89 VW Cabriolet - 2.0 conversion - sold and missed |
AirBorne!
Oooops. What a Freudian slip. Meant to say "shouldn't kill the cat."
Try some light polish compound. If they don't come out, try a little coarser compound. If they are not through the paint, you should be able get them out or at least not be too noticeable.
AS for the cat? .45
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Semper drive!
Wayne,
I don't think 45 is fast enough. If you're gonna sling it out the window, you definitely need to be in the triple digit speed range. ![]() Randy
84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )One Marine's View Igitur qui desiderat pacem, praeparet bellum |
one of gods prototypes
apache could take care of the situation....
kidding of course
Brought to you by Carl's Jr. |
Banned
hi Jackman,
same thing happened to my 930 last week with neighbors dog. Here's what I did, and you cant even see the scratches at all. Get yourself a random orbital sander, Sears has a 10" for like $40 right now on sale. Wash your car with Dawn to remove any old junky wax. Then use Mequier's Fine Cut Cleaner and a Meguire's yellow pad. Use the sander in the area affected, until the cleaner is almost dry. Wipe clean with a microfiber cloth. Repeat, until the entire area on the car is done this way, you need to go at least 10" around the scratches...to blend the paint in so to speak. Using a new Yellow Pad and Mequire's Swirl Remover 2.0. Again, the area affected, worked until almost dry. Wipe it off again with the microfiber and redo, until the area is done same way. Now if you want to add overall gloss to your car and really blend your paint in so you cant notice anything then this would be a good time to get some 3M rubbing hand glaze and using your hands, not the sander, polish and rub the entire car down. Your car should look better than showroom new, if not, redo the 3M one more time. It takes time. If you still have scratches, then you will need to use a stronger polish to get those out or some claybars, although you will be lifting some of your paint with them, so be gentle when your using those. you can then finish up with the Mequires #20 wax to seal in the 3M polish/gloss and their tan pad and you should be looking like a Concours winner
Detached Member
Antifreeze? Why was it a Freudian slip? What EXACTLY were you going to do to that cat?
Hugh |
Senior Registered User
Double tap the cat. Pop,pop!
*******s and Porsches don't mix :-) Randy Jones 1971 911 "Iris" |
1st try Meguiar's Scratch-X or similar
2nd go with Body Scrub and a wool pad on a random orbit machine only 3rd Find a GOOD body shop & pay them
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
RETIRED
Grind the cat into a paste, add silver paint, blot on with a sponge....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
#1, kick the ***** out of the cat and then have it declawed. #2 Ask questions on the Pelican board how to fix your paint. #3 Fix paint.
"It looks like a Pleco.." |
First, when handling cats around Porsches use the below tool made for this purpose:
Next, at worst it will need some color sanding, minor polishing and all should be well unless the cat claws went all the way through the paint in which case you should give the cat away humanely like this:
Dan in Pasadena '76 911S Sahara Beige/Cork |
Air Medal or two
Ahem..1st what paint is it reg. or base coat clear coat (I hope) "if all else fails this trick works...get the proper collor, dab in the scatches with your favorit aplicator have some clear coat with you ( I rob it from my favorit body shop as there is allways some left over- call 1st ) dab the clear in/on wait till it kicks,block it dwn, buff, lil wax and poof know one will ever be able to tell.
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
AirBorne!
Wow. Thanks for the tips. I am no longer feverish about what happened. Yesterday I was in a funk, a deep anti-cat funk.
Given my past history with paint, not good, I think I'll check with some body shop friends of mine. Bell, send Apache on over. You're not too far away. Wellborn
You can also try paintscratch.com. For about $25 you can get a kit that come with two "pens" one basecoat & one clearcoat.
1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing" |
If you have no experience with buffing out scratches..... dont practice on a car you care about. Stop by a small body shop... shake some hands, see if they will do it right there. takes 2 minutes by a pro.
As for an orbital . ..911 fenders have all curves. Practice on an old car... or wifes. Buffing is an art. HAND BUFFING DOESN"T WORK, never consistent.... ask a pro.
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted. |
I hate when these threads deteriorate into animal bashing hating from idiots who are just plain cold hearted with extremely ball less smalldickked low self esteem....
I agree with ken_xman, Do not mess with it unless you are a pro. Where is Hudson? I am just north of Toledo and can help you out.
87 Carerra Coupe 04 GMC Yukon 07 Mazda 3 00 GMC Sierra |
Somatic Negative Optimist
I agree with the body-shop solution for the scratches. (Or de-claw the cat and tie it to a 10-inch polisher and see if you can get the scratches out using the culprit as a buffer)
Good replies. I am no friend of cats; they are not a natural ingredient in the environment; they kill needlessly, especially song-birds, garden snakes, etc. Cats are a man-made nuisance. The unneutered males spray and stink up your front door or porch. Female cats, when not spayed, produce unbelievable amouts of kittens. Yes, cats are a man-made problem. Every year, a few wild ones come through and hang around my 30 plus bird houses. A 22 caliber is pretty good in such cases. No sympathy for cats.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Tell ya what, why don't you go hang out with forest creatures like Timothy Treadwell did, and leave the higher order thinking skills to the rest of us. I'm sure Mr. Fuzzy is missing the quality time they spent together. Nice grizzly.
1970 914-6 |
