one person power auger
Need to install about 300' of split rail fence soon in fairly rocky soil - anyone ever used one of these? Looks safer than the standard type that I've seen. I've only used a manual post hole digger before and I'm getting too old for that!
1957 Speedster, 1965 356SC, 1965 356SC Outlaw, 1972 911T, 1998 993 C2S, 2018 Targa 4 GTS, 2014 Cayenne S, 2016 Boxster Spyder, 2019 Tacoma |
i think that would work if the land is nice and flat. i have used that hand held unit, and it kills.
last time i did 400", i rented a small bobcat, with an auger attachment. once we figured out how to drive it, we were at 50 seconds per hole. in hard clay. i wanted to hug myself with happiness. worth the $300.
poof! gone |
Unoffended by naked girls
Looks more stable than the two-man that I've used before.
Rocky soil. Sounds like fun....
Dan 1969 911T (sold) 2008 FXDL www.labreaprecision.com www.concealedcarrymidwest.com |
It is flat so I'm thinking this might work nicely - I like the bobcat idea too, I'll have to see what I can get. I don't think it's too rocky from my sample digging, but it's not pure topsoil either. Should be a fun day! I better get the beer meister hooked up first..
Parrothead member
That looks like a good one. I almost snapped my arm with one of those hand held power ones.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
Cars & Coffee Killer
Do they make fully manual ones? I need to dig two fence post holes and renting a powered one seems overkill.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
two holes? post hole digger and a digging bar. apply beer as needed. my record is 13 holes in my soil, in one day. i hated life.
poof! gone |
Unconstitutional Patriot
If you don't have the means to haul a bobcat, rent a compact tractor with post hole digger.
A lot of the performance of the system will depend on the diameter of the auger: 10'' and below works smoothly in most soils. Have fun!
1996 FJ80. |
The compact tractor version doesn't have much down force compared to the Bobcat. I put in 400' of fencing with the behind the tractor model and it bounced every time it hit a root or rock.
Don't forget to call Miss Utility or your state equivalent. They will come and mark underground utilities for free.
07 997 cab sold 95 993 cab sold 87 911 cab sold |
Targa, Panamera Turbo
Alternatives:
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
You're bad Lube. Funny, but bad.
I've tried one of those and it was worthless. But that was because the auger was old and worn, and the ground was hard. I took it back for a new auger, and the dufus at the rental place just scratched his head and said, "Duh that's the only auger we got." I told him it wouldn't cut butter and got my money back. Don't rent it unless the auger is in good shape.
Charlie 1966 912 Polo Red 1950 VW Bug 1983 VW Westfalia; 1989 VW Syncro Tristar Doka |
The Mexican alternative would still require at least 3 man/days to hand dig 40 holes not including your transportation time and lunch etc. if it takes one man one day to do 13 holes.
Ask around the rental places if they have a Toro Dingo or similar. They are basically walk behind mini skid steer loader that you can haul in the back of a pickup.
In the shop at Pelican
I did a five acre perimeter with only a manual post hole digger. took me all day. Power sheesh... we dont need no steenkin power
I used one of those one-man augers last year... worked great. The ground had lots of rocks & roots so it took 2 days, but I did it without getting a sore back. Those two-man augers should be outlawed.
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats |
notfarnow - you used the one in the pic (tow behind) or the one man hand-held?
Sorry, my earlier post wasn't very clear. I used the one in the pic. It had smaller wheels, which made it a bit awkward, but otherwise exactly the same.
Very easy to use, and I had no problem moving it around on my own. Don't even consider the cheaper upright ones where a guy holds either side. They are horrible, hateful devices. People that design sell and rent those things should spend their afterlives digging holes to hell using them.
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats Last edited by notfarnow; 03-23-2006 at 10:08 AM.. |
Thanks, good to know. I have visions of my arms being ripped off with the hand-held ones. I imagine there has to be some type of clutch in there though...
It's hydraulic. The motor drives a pump, and the speed and reverse/forward controls are on the handle. Mine was a b#tch to start, but worked like a million bucks once it was running.
