Banned
IIRC the later Vanagons came with watercooled engines and pretty good fuel injection. Which years were they made, and do the engines bolt up to regular VW beetle transmissions?
In the shop at Pelican
yes, although im pretty sure the flywheel, clutch and TO bearing arent the same. think you'd need to do your homework to figure out the correct combo to clear the bellhousing. You'll also need to figure out a way to mount a radiator and get airflow to it. mid 83 is when they started
In my opinion, it's a waste of time. Get a Type 4 or build a Type 1 into something bigger and better. |
Banned
Call Lucas at GoWesty. They sell nice water cooled engines with a little extra HP, and Lucas will know everything you need to know.
Charlie 1966 912 Polo Red 1950 VW Bug 1983 VW Westfalia; 1989 VW Syncro Tristar Doka |
Banned
Looks interesting, so far. |
Glad to be of help. Lucas used to build off-road race cars with driver Craig Watkins at the highest level of off-roading, back in the 80's. He's a great resource.
If no one answers my Vanagon question, I'll be calling him too. See Towing with a Vanagon?
Banned
Banned
Very cool, the GoWesty 147 page catalog is available as a .pdf download, and is chock full of details on Vanagons of every year. Worth the download time.
Pat,
The website has a lot more info than can fit on the the catalog, so more perusal of the website is worthwhile.
Have you thought about going with a Subaru motor instead? Plenty cheap from the JDM, probably a bit more power than an old VW water pumper too.
'75 911S 3.0L '75 914 3.2 Honda J '67 912R-STi '05 Cayenne Turbo '99 LR Disco 2, gone but not forgotten |
Banned
The reason for thinking VW Vanagon is tranny to engine compatibility. Would the Subie engine bolt up without an adapter? |
You might look around a bit, Subaru turbo engines mated to bus trannys are a hot ticket in the dune-buggy world. Check out any Hot VWs mag, they are all over the place. I dare to say that you'll definitely need an adapter, but there should be plenty of kits out there.
http://www.nmcollector.net/buggy/fugitive/adapter.htm
Banned
