Soap Box Derby
My daughter and I are setting up a Soap Box Derby car for the city race next month.
Anyone have any advice for us?
74 911 coupe (gemini metallic)
86 928
91 Springer Softtail
Old 05-14-2006, 03:31 PM
Designer King
Paulporsche's Avatar
Get the weight over the FRONT wheels.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-14-2006, 04:50 PM
Paul,
Why the front? I would guess that the rear would be better, if not the center for equal corner weights. Weight in the rear would be "higher" on the launch ramp and have more potential energy.
Brian
86 928
Old 05-14-2006, 05:09 PM
Designer King
My mistake. Actually the car should be very nearly balanced front to rear. If the start ramp is great compared to the track slope, then the car should be rear heavy for the reason you mentioned. If the difference between the ramp and track is less, then the weight should be moved more foreward. If there was no start ramp, just a sloped track, then the weight should be more forward. All this is theoretical since once one end gets more loaded, then the resistance on the wheels of that end move more slowly. I would think a car w/ more front bias would be easier to steer straight, but that may be moot on these cars. In any case, for a tuopical track, apparently a very slight rear bias on a steep start ramp will give you a better start ineretia, while a car w/ a very slight front bias might actually travel down the track slightly faster. Because of this, conventional wisdom seems to be to go w/ a balanced car. There is also a limit to how much rear weight bias you can have on these things.
Paul
Old 05-14-2006, 06:05 PM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
when I did pinewood derby with son for scouting project (same basic pricipal only a lot smaller) my car with the weight over the front wheels went a lot faster than his with weight in the middle...I think it might have something to do with it pulling the car from the start as opposed to having to push it....to put it in very simple uneducated words
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 05-14-2006, 06:08 PM
Paul,
Thanks for the insight. What is your feelings / experience with 1) camber, 2) toe in, and 3) rigidity of axles relative to the car?
Also, do you know of the "proper" way to lubricate the z-glas wheels?
Thanks agian, Brian
86 928
limble's Avatar
My daughter and I did it for several years and the rules then were very strict about where you can put the weight.
They weigh the car before every race.
I have some old wheels that you are welcome to. PM your address.
You can use them to set up and test the car.
All I ask is you put a 911T registry sticker somewhere on the car. I'll send the sticker and you can send a picture of the car to me for the 911T registry site.
Here is the sticker.
Thanks,
Mike
When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE.
1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation)
Old 05-14-2006, 07:12 PM
coloradoporsche's Avatar
They're putting 911's in the soapbox derby?
Can’t wait to see the pictures.
Sheena is a punk rocker
Suzy Is A Headbanger
Heidi Is A Headcase
Judy Is A Punk
The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'."
Old 05-14-2006, 07:18 PM
Mike,
Thanks for the offer, most gracious. The race is the about a month away, so I've cut myself short for much testing. Also, the car we're using is sponsored by my Rotary Club, and they have expressed sensitivity to decals and such.
What I really would like to know is if there is any "magic" to "running in" the wheels I have that came with the car. They are called Z-glass. The rules seem to imply you can lubricate them prior to the race, but not during. I've spun them quite a bit by pressing the chuck of my power drill to the tread, and the bearings make a lot of noise. Graphite makes them run much quieter. Too much graphite and they slow. Is this the best I can do?
Also, the rules state that I can bend the axles to create toe-in and camber. Is this a good idea?
BTW, how did you fare in the races you ran?
Thanks,
Brian
86 928
Old 05-14-2006, 08:39 PM
Designer King
I have heard that people bend tha axles down slightly to preload them so that the driver's weight straightens them back, resulting in zero camber. By the same logic, maybe you want slight toe in, which will return to zero as the car rolls down the track? We're talking .025" here.
Paul
Old 05-14-2006, 08:50 PM
have you tried a google to see what some "pros" have to say.....I am sure the web is full of information that could be used....I am also sure there are several ways to use the rules to the limit to gain the best performance....there might even be a board such as this to gain lots of useful information.
Don Booth
70 911 T Coupe
74 914
Old 05-14-2006, 09:54 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Go that way, really fast. If something gets in your way, turn.
Old 05-15-2006, 12:05 AM
AirBorne!
Give me a call. My son and I run the Derby cars. We have all the go fast secrets. We're based in Hudson, just 20 minutes from Derby Downs.
Wellborn
330-592-1605
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1975S to 1970s w 3.0 PMO - Roxanne, 1967 911 normal w 2.2s engine w S goodies, 89 VW Cabriolet - 2.0 conversion - sold and missed
Old 05-15-2006, 10:28 AM
Dept store Quartermaster
lendaddy's Avatar
"Do you realize the street value of this mountain?"
Cornpoppin' Pony Soldier
Old 05-15-2006, 12:35 PM
limble's Avatar
This was 12 years ago so the rules must have changed. We had to run wheels that were supplied by the zone who was sponsoring the race. And then they were swapped every race. I guess it levels the playing field. We did okay, got a couple of trophies.
My wife and I were both in college at the time so we didn't have much extra money for travel to races but we sure had fun at the ones we did.
I volunteered downhill putting cars back on the trailer for the trip back up. If you have a bad back don't take that duty.
Have fun. Post pics.
I understand about the sticker. If you want the wheels I'll send them along anyway. Maybe you can use them next year. Actually I have all of the hardware, axles, steering etc. You are welcome to all or any of it.
i can't bring myself to put it in the trash.
Thanks,
Mike
Old 05-15-2006, 08:10 PM
"I've been going to this high school for seven years, ........I'm no dummy!"
"Everybody from the entire state of Northern California is gonna be there....."
Sorry I was no help, but Beth is my favorite name.
http://en.wikipedia.org/wiki/Better_Off_Dead
Old 05-15-2006, 09:23 PM
http://www.youtube.com/watch?v=_K1XGjHqyaI&search=everybody%20wants%20some
classic
Old 05-15-2006, 09:42 PM
