Air Compressor Quick Question
I recently appropriated an older but still functional 120VAC 5gal air compressor for the garage etc. Only problem is 5 gallons isn't really enough capacity - runs out of pressure pretty quickly and is almost constantly running. Can't keep up when I'm using the air hose for cleaning dust/leaves out of the engine bay and such.
Can I get one of those 11 gal "portable" carry tanks and re-plumb it (very comfortable doing that) to use as a reserve tank? Big safety issues, anything I should worry about?
Ned
1983 944 with S2 motor, trans, suspension and exterior -- crunched parts car
1987 944 -- soon to be 1987 944S2
Old 05-18-2006, 03:00 PM
Re: Air Compressor Quick Question
Yes. Tee the fill side and install a one-way check valve so you can keep using it in portable mode if need be.
Old 05-18-2006, 03:18 PM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
Your compressor will be running even more as it's trying to fill nearly three times the volume.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 05-18-2006, 03:29 PM
True, but once filled it should hold pressure longer. Not too concerned about it running but it just couldn't keep up with the amount of air it needed at one time. Thanks for your replies!
Old 05-18-2006, 04:04 PM
The real solution is to get a larger compressor, but the larger tank will help by giving you a larger buffer and should make the current setup more livable.
Old 05-18-2006, 04:14 PM
