Air Compressor Quick Question
I recently appropriated an older but still functional 120VAC 5gal air compressor for the garage etc. Only problem is 5 gallons isn't really enough capacity - runs out of pressure pretty quickly and is almost constantly running. Can't keep up when I'm using the air hose for cleaning dust/leaves out of the engine bay and such.
Can I get one of those 11 gal "portable" carry tanks and re-plumb it (very comfortable doing that) to use as a reserve tank? Big safety issues, anything I should worry about? Thanks Ned
1983 944 with S2 motor, trans, suspension and exterior -- crunched parts car 1987 944 -- soon to be 1987 944S2 |
Re: Air Compressor Quick Question
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
1.367m later
Your compressor will be running even more as it's trying to fill nearly three times the volume.
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
The real solution is to get a larger compressor, but the larger tank will help by giving you a larger buffer and should make the current setup more livable.
