I need on of these are a fan selector in our Vanagon, anyone know where I can buy one? It need to be beefy enough to carry the current of the fan, so 10amp maybe at 12 volts.
thanks in advance for any help Jim
Jim Hamilton If everything seems under control, your not going fast enough. |
Senior Member
McMaster Carr.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Jim,
Questions: Are you trying to assemble an aftermarket setup? Is there a factory part available? For this car or maybe another you can rob..from a salvage yard? I assume you want 3 speeds. 0/off is considered one position. Newark Electronis may have what you want if MC doesn't pan out.
Warren & Ron, may you rest in Peace. |
McMaster Carr. looks like a cool place I will call them on Tuesday.
I am replacing the switch on an afermarket AC system, the original switch had a four position (off, low, med, and hi) and some kind of variable resistor or something for controling temperature. The veriable part is OK, so I was planning on using it and just re-wiring the fan switch. Here are some pictures of the original switch ![]() ![]()
